MSTP configuration: My MSTP on two Zyxel Switches seems splitted
I have a XMG1930-30HP and a XS1930 switch (both with L3 license; patch level from July 2023) and try to get multiple Sonos S1 speakers working/connecting on them only connected with Ethernet cable. I run multiple VLANs on the two switches, which works well. In two of the VLANs there are Sonos devices present, that do STP. Besides the recommendation from Sonos to just let all BPDU packets flood through (see my other questions), I also tried to configure MSTP on the VLANs to ensure, I have proper spanning trees running and let the XMG1930-30HP be the root bridge for all VLANs. Sonos with its old STP implementation should integrate then there. Priorities and timings are all set according to the recommendations from Sonos in their support doc:
https://support.sonos.com/en-us/article/configure-stp-settings-to-work-with-sonos
(Each sonos system will only be accessed within the same VLAN, so no isolated Sonos VLAN or so and inter-vlan routing needed.)
When I configure MSTP on the Zyxel switches and add all VLANs, configure same configuration name, revision and timing/aging parameters on both switches, even after a few hours it looks like each switch is becoming its own root bridge and not knowing about the other. Also doing the same on a connected MikroTik Cloud Core router shows the same picture. Seems not to be integrated in the topology.
I also had some crashes of the XMG1930-30HP with the current 4.80 firmware when I changed something there.
Do I need a special "BPDU Ctrl" mode for running MSTP? e.g. does it only work properly with "Peer" set for all ports? Or doesn't that matter at all?
BPDU Root Guard is not active. BPDU Transparency is enabled.
In the "Spanning Tree Protocol Status" view under the MSTI view I also never see any ports listed. Nothing.
What am I doing wrong?
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,984 image  Guru Member
    Hi @StefanNetworker,
    Based on your configuration, the MSTP port status is empty because MSTP was inactive on any ports of instance 0. This causes the switch not to send any BPDU.
    I use your configuration and the MSTP works after I active MSTP on instance 0 port 1.
    Here's the result:
    Zyxel Melen
  • Zyxel_Melen
    edited September 2023
    After you enable MSTP, you have to set up instances for the VLANs and the ports to run MSTP. Or you won't find any ports running MSTP in MSTI view.
    Click the "Add/Edit" button to set up an instance.
    Here's a simple result:
    To better help you solve this problem, could you provide a simple topology about which port connects a Sonos device and the configuration of your switches for me to check if there is any misconfiguration?
    And how many Sonos S1 in your network
    Zyxel Melen
  • Hi Melen,
    it is set up with all the elements that you mention. But for me on current firmware the list on the status page showing the role of the ports is empty. This makes debugging super hard. Also on CLI (I have a L3 license) there is nothing shown for MSTP status. Command does return with empty response.
    Topology is not complicated:
    2 Switches (XMG1930-30HP, XS1930-10HP) connected over fiber on the SFP+ ports (port 29). Additionally there is a MikroTik Cloud Core Router 2004-1G-12S+2XS connected over DAC on the 2nd SFP+ port (port 30) on the XMG1930.
    On 3 ports (Port 2,4,6 of the XMG1930) there are 3 Zyxel NWA210AX wifi access points connected which are powered by the switch over PoE and use VLANs as well for the different WIFI SSIDs. All that works fine.
    Essentially there are multiple isolated VLANs which realize different isolated networks. No connection between these VLANs. You can see them as completely isolated. They are only accessible over the router for some special cases. Broadcast and multicast domains are only inside the VLANs.
    I want MSTP active on all of them. Every VLAN should have its own instance.
    The VLANs span over both switches and also the access points and the MikroTik router as well. That all works well.
    On the XMG1930 config below you can also see, that some ports are attached to VLAN 1 (which is my mgmt VLAN where also some equipment for controlling the whole house is in) and VLAN 10 exclusively. That is intentionally.
    The rate limits and errdisable detect are only there because of some Sonos devices to avoid broadcast/multicast storms, where I had serious problems in the beginning. Multicast storm is gone since IGMP Snooping is active. Broadcast storm was not present anymore after disabling WIFI on all Sonos devices, so that the loops are gone.
    I only want to activate MSTP because I have on VLAN 10 and VLAN 30 (for two isolated networks for 2 isolated entities) Sonos S1 players (multiple Sonos Play:5 and Play:1) active, which always do STP. As on Sonos you cannot disable it, I assume it is better to have it run / controlled by the more powerful switch in the heart of the network.
    As I have multiple VLANs, I think I need to use MSTP, which should be compatible with the old STP implementation of Sonos, to ensure, the VLANs are treated accordingly.
    See here my configuration (export also attached):
    ; Product Name = XMG1930-30HP
    ; Firmware Version = V4.80(ACAS.2) | 06/21/2023
    ; Service Status = Access L3
    ; SysConf Engine Version = 1.2
    ; Config last updated = 09:03:55 (UTC+00:00) 2023-09-08
    no service-control telnet
    no service-control ftp
    no service-control snmp
    no remote-management 1 service telnet ftp snmpno cloud center discovery
    vlan 1
    name mgmt
    normal ""
    fixed 1-12,29-30
    forbidden 13-28
    untagged 1-28
    ip address 192.168.88.2 255.255.255.0
    exit
    vlan 10
    name hw-1
    normal ""
    fixed 2,4,6,13-26,28-30
    forbidden 1,3,5,7-12,27
    untagged 1,3,5,7-28
    ip address 192.168.20.2 255.255.255.0
    ip address default-gateway 192.168.20.1
    exit
    vlan 11
    name hw-2
    normal ""
    fixed 2,4,6,29-30
    forbidden 1,3,5,7-28
    untagged 1,3,5,7-28
    ip address 192.168.21.2 255.255.255.0
    exit
    vlan 30
    name hw-guest
    normal ""
    fixed 2,4,6,29-30
    untagged 1,3,5,7-28
    exit
    vlan 70
    name ew
    normal ""
    fixed 2,4,6,27,29-30
    forbidden 1,3,5,7-26,28
    untagged 1,3,5,7-28
    exit
    vlan 80
    name ew-guest
    normal ""
    fixed 2,4,6,29-30
    untagged 1,3,5,7-28
    exit
    igmp-snooping
    igmp-snooping unknown-multicast-frame drop
    igmp-snooping vlan 1igmp-snooping vlan 10igmp-snooping vlan 11igmp-snooping vlan 30igmp-snooping vlan 70igmp-snooping vlan 80igmp-snooping querier
    interface route-domain 192.168.20.2/24
    exit
    interface route-domain 192.168.21.2/24
    exit
    interface route-domain 192.168.88.2/24
    exit
    interface port-channel 1
    name "B6 - DG (VID 1 Mgmt Port)"
    lldp org-specific-tlv dot3 link-aggregation
    lldp org-specific-tlv dot3 max-frame-size
    frame-type untagged
    cpu-protection cause BPDU rate-limit 100
    exit
    interface port-channel 2
    name "A11 - EG WZ - Access Point"
    exit
    interface port-channel 3
    name "CCR Mgmt"
    frame-type untagged
    dhcp snooping trust
    dhcp server trust
    exit
    interface port-channel 4
    name "A17 - OG Flur - Access Point"
    exit
    interface port-channel 5
    name "KNX IP Interface"
    frame-type untagged
    exit
    interface port-channel 6
    name "B5 - DG - Access Point"
    exit
    interface port-channel 7
    name "zimaboard 1 HW vid 1"
    frame-type untagged
    exit
    interface port-channel 8
    name "VID 1 Mgmt Port"
    frame-type untagged
    exit
    interface port-channel 9
    name "zimaboard 2 EW vid 1"
    frame-type untagged
    exit
    interface port-channel 10
    name "Keba Wallbox"
    frame-type untagged
    exit
    interface port-channel 11
    name "Vallox ValloPlus 510 MV-E"
    frame-type untagged
    exit
    interface port-channel 12
    name "Fenecon FEMS"
    frame-type untagged
    exit
    interface port-channel 13
    pvid 10
    frame-type untagged
    exit
    interface port-channel 14
    name "B7 - DG Bad - Sonos"
    pvid 10
    frame-type untagged
    broadcast-limit
    broadcast-limit 100
    multicast-limit
    multicast-limit 50
    mirror
    mirror dir both
    exit
    interface port-channel 15
    name "A12 - EG WZ - Sonos"
    pvid 10
    frame-type untagged
    broadcast-limit
    broadcast-limit 100
    multicast-limit
    multicast-limit 50
    mirror
    mirror dir both
    exit
    interface port-channel 16
    name "B9 - DG SZ - Sonos"
    pvid 10
    frame-type untagged
    broadcast-limit
    broadcast-limit 100
    multicast-limit
    multicast-limit 50
    mirror
    mirror dir both
    exit
    interface port-channel 17
    pvid 10
    frame-type untagged
    exit
    interface port-channel 18
    pvid 10
    frame-type untagged
    exit
    interface port-channel 19
    pvid 10
    frame-type untagged
    exit
    interface port-channel 20
    pvid 10
    frame-type untagged
    exit
    interface port-channel 21
    pvid 10
    frame-type untagged
    exit
    interface port-channel 22
    name "B1 - DG"
    pvid 10
    frame-type untagged
    exit
    interface port-channel 23
    name "B3 - DG - Sonos Port"
    pvid 10
    frame-type untagged
    broadcast-limit
    broadcast-limit 100
    multicast-limit
    multicast-limit 50
    exit
    interface port-channel 24
    name "B2 - DG"
    pvid 10
    frame-type untagged
    exit
    interface port-channel 25
    name Diskstation
    pvid 10
    frame-type untagged
    exit
    interface port-channel 26
    name Diskstation
    pvid 10
    frame-type untagged
    exit
    interface port-channel 27
    name "zimaboard 1 HW vid 70"
    pvid 70
    frame-type untagged
    exit
    interface port-channel 28
    name "zimaboard 2 EW vid 10"
    pvid 10
    frame-type untagged
    exit
    interface port-channel 29
    name "CCR Router Trunk"
    speed-duplex 10G-full
    media-type 10g DAC10G
    frame-type tagged
    dhcp snooping trust
    dhcp server trust
    exit
    interface port-channel 30
    name "EW Switch"
    frame-type tagged
    exit
    ip name-server 192.168.20.1
    mirror-port 22
    lacp
    trunk T1 lacp
    trunk T1 interface 25
    trunk T1 interface 26
    spanning-tree mode MSTP
    spanning-tree auto-path-cost mode short
    spanning-tree 1
    spanning-tree 2
    spanning-tree 3
    spanning-tree 4
    spanning-tree 5
    spanning-tree 6
    spanning-tree 7
    spanning-tree 8
    spanning-tree 9
    spanning-tree 10
    spanning-tree 11
    spanning-tree 12
    spanning-tree 13
    spanning-tree 14
    spanning-tree 15
    spanning-tree 16
    spanning-tree 17
    spanning-tree 18
    spanning-tree 19
    spanning-tree 20
    spanning-tree 21
    spanning-tree 22
    spanning-tree 23
    spanning-tree 24
    spanning-tree 25
    spanning-tree 26
    spanning-tree 27
    spanning-tree 28
    spanning-tree 29
    spanning-tree 30
    spanning-tree 1 edge-port
    spanning-tree 3 edge-port
    spanning-tree 5 edge-port
    spanning-tree 7 edge-port
    spanning-tree 9 edge-port
    spanning-tree 10 edge-port
    spanning-tree 11 edge-port
    spanning-tree 12 edge-port
    spanning-tree 13 edge-port
    spanning-tree 14 edge-port
    spanning-tree 15 edge-port
    spanning-tree 16 edge-port
    spanning-tree 17 edge-port
    spanning-tree 18 edge-port
    spanning-tree 19 edge-port
    spanning-tree 20 edge-port
    spanning-tree 21 edge-port
    spanning-tree 22 edge-port
    spanning-tree 23 edge-port
    spanning-tree 24 edge-port
    spanning-tree 25 edge-port
    spanning-tree 26 edge-port
    spanning-tree 27 edge-port
    spanning-tree 28 edge-port
    mstp
    mstp configuration-name LT1
    mstp instance 0 vlan 2-9,12-29,31-69,71-79,81-4094
    mstp instance 1 vlan 1
    mstp instance 2 vlan 10
    mstp instance 3 vlan 11
    mstp instance 4 vlan 30
    mstp instance 5 vlan 70
    mstp instance 6 vlan 80
    mstp instance 0 priority 4096
    mstp instance 1 priority 4096
    mstp instance 2 priority 4096
    mstp instance 3 priority 4096
    mstp instance 4 priority 4096
    mstp instance 5 priority 4096
    mstp instance 6 priority 4096
    mstp instance 1 interface port-channel 1
    mstp instance 1 interface port-channel 2
    mstp instance 1 interface port-channel 3
    mstp instance 1 interface port-channel 4
    mstp instance 1 interface port-channel 5
    mstp instance 1 interface port-channel 6
    mstp instance 1 interface port-channel 7
    mstp instance 1 interface port-channel 8
    mstp instance 1 interface port-channel 9
    mstp instance 1 interface port-channel 10
    mstp instance 1 interface port-channel 11
    mstp instance 1 interface port-channel 12
    mstp instance 1 interface port-channel 29
    mstp instance 1 interface port-channel 30
    mstp instance 2 interface port-channel 2
    mstp instance 2 interface port-channel 4
    mstp instance 2 interface port-channel 6
    mstp instance 2 interface port-channel 13
    mstp instance 2 interface port-channel 14
    mstp instance 2 interface port-channel 15
    mstp instance 2 interface port-channel 16
    mstp instance 2 interface port-channel 17
    mstp instance 2 interface port-channel 18
    mstp instance 2 interface port-channel 19
    mstp instance 2 interface port-channel 20
    mstp instance 2 interface port-channel 21
    mstp instance 2 interface port-channel 22
    mstp instance 2 interface port-channel 23
    mstp instance 2 interface port-channel 24
    mstp instance 2 interface port-channel 25
    mstp instance 2 interface port-channel 26
    mstp instance 2 interface port-channel 28
    mstp instance 2 interface port-channel 29
    mstp instance 2 interface port-channel 30
    mstp instance 3 interface port-channel 2
    mstp instance 3 interface port-channel 4
    mstp instance 3 interface port-channel 6
    mstp instance 3 interface port-channel 29
    mstp instance 3 interface port-channel 30
    mstp instance 4 interface port-channel 2
    mstp instance 4 interface port-channel 4
    mstp instance 4 interface port-channel 6
    mstp instance 4 interface port-channel 29
    mstp instance 4 interface port-channel 30
    mstp instance 5 interface port-channel 2
    mstp instance 5 interface port-channel 4
    mstp instance 5 interface port-channel 6
    mstp instance 5 interface port-channel 27
    mstp instance 5 interface port-channel 29
    mstp instance 5 interface port-channel 30
    mstp instance 6 interface port-channel 2
    mstp instance 6 interface port-channel 4
    mstp instance 6 interface port-channel 6
    mstp instance 6 interface port-channel 29
    mstp instance 6 interface port-channel 30
    mstp instance 1 interface port-channel 2 path-cost 6
    mstp instance 1 interface port-channel 4 path-cost 6
    mstp instance 1 interface port-channel 6 path-cost 6
    mstp instance 2 interface port-channel 2 path-cost 15
    mstp instance 2 interface port-channel 4 path-cost 15
    mstp instance 2 interface port-channel 6 path-cost 15
    mstp instance 2 interface port-channel 14 path-cost 10
    mstp instance 2 interface port-channel 15 path-cost 10
    mstp instance 2 interface port-channel 16 path-cost 10
    mstp instance 2 interface port-channel 23 path-cost 10
    mstp instance 3 interface port-channel 2 path-cost 6
    mstp instance 3 interface port-channel 4 path-cost 6
    mstp instance 3 interface port-channel 6 path-cost 6
    mstp instance 3 interface port-channel 14 path-cost 10
    mstp instance 3 interface port-channel 15 path-cost 10
    mstp instance 3 interface port-channel 16 path-cost 10
    mstp instance 3 interface port-channel 23 path-cost 10
    mstp instance 4 interface port-channel 2 path-cost 6
    mstp instance 4 interface port-channel 4 path-cost 6
    mstp instance 4 interface port-channel 6 path-cost 6
    mstp instance 5 interface port-channel 2 path-cost 6
    mstp instance 5 interface port-channel 4 path-cost 6
    mstp instance 5 interface port-channel 6 path-cost 6
    mstp instance 6 interface port-channel 2 path-cost 6
    mstp instance 6 interface port-channel 4 path-cost 6
    mstp instance 6 interface port-channel 6 path-cost 6
    mstp instance 4 interface port-channel 2 priority 64
    mstp instance 4 interface port-channel 4 priority 64
    mstp instance 4 interface port-channel 6 priority 64
    mstp interface port-channel 1 edge-port
    mstp interface port-channel 3 edge-port
    mstp interface port-channel 5 edge-port
    mstp interface port-channel 7 edge-port
    mstp interface port-channel 8 edge-port
    mstp interface port-channel 9 edge-port
    mstp interface port-channel 10 edge-port
    mstp interface port-channel 11 edge-port
    mstp interface port-channel 12 edge-port
    mstp interface port-channel 13 edge-port
    mstp interface port-channel 17 edge-port
    mstp interface port-channel 18 edge-port
    mstp interface port-channel 19 edge-port
    mstp interface port-channel 20 edge-port
    mstp interface port-channel 21 edge-port
    mstp interface port-channel 22 edge-port
    mstp interface port-channel 24 edge-port
    mstp interface port-channel 25 edge-port
    mstp interface port-channel 26 edge-port
    mstp interface port-channel 27 edge-port
    mstp interface port-channel 28 edge-port
    mstp interface port-channel 29 edge-port
    timesync server 1.pool.ntp.org
    timesync ntp
    bcp-transparency
    storm-control
    snmp-server version v3
    snmp-server get-community sk24
    snmp-server set-community sk24
    snmp-server trap-community sk24
    service-control http 80 30
    service-control telnet 23 15
    dhcp option profile everything circuit-id slot-port vlan hostname remote-id mac
    dhcp snooping vlan 1,10-11,30,70,80dhcp snooping vlan 1,10-11,30,70,80 option profile everything
    rmon statistics etherstats 1 port-channel 1rmon statistics etherstats 2 port-channel 2rmon statistics etherstats 3 port-channel 3rmon statistics etherstats 4 port-channel 4rmon statistics etherstats 5 port-channel 5rmon statistics etherstats 6 port-channel 6rmon statistics etherstats 7 port-channel 7rmon statistics etherstats 8 port-channel 8rmon statistics etherstats 9 port-channel 9rmon statistics etherstats 10 port-channel 10rmon statistics etherstats 11 port-channel 11rmon statistics etherstats 12 port-channel 12rmon statistics etherstats 13 port-channel 13rmon statistics etherstats 14 port-channel 14rmon statistics etherstats 15 port-channel 15rmon statistics etherstats 16 port-channel 16rmon statistics etherstats 17 port-channel 17rmon statistics etherstats 18 port-channel 18rmon statistics etherstats 19 port-channel 19rmon statistics etherstats 20 port-channel 20rmon statistics etherstats 21 port-channel 21rmon statistics etherstats 22 port-channel 22rmon statistics etherstats 23 port-channel 23rmon statistics etherstats 24 port-channel 24rmon statistics etherstats 25 port-channel 25rmon statistics etherstats 26 port-channel 26rmon statistics etherstats 27 port-channel 27rmon statistics etherstats 28 port-channel 28rmon statistics etherstats 29 port-channel 29rmon statistics etherstats 30 port-channel 30pwr mode consumption
    errdisable recovery cause BPDU
    errdisable recovery cause IGMP
    errdisable detect cause ARP
    errdisable detect cause BPDU
    errdisable detect cause IGMP
    errdisable detect cause ARP mode rate-limitation
    errdisable detect cause BPDU mode rate-limitation
    errdisable detect cause IGMP mode rate-limitation
    wizard ignore
  • Any ideas, what is wrong here?
  • Zyxel_Melen
    Here's the result:
    Zyxel Melen
  • Thanks! You are right. After setting all ports on instance 0 (which only contains unused VLANs) to active, it works fine. Port list is shown and also on neighbouring switches root is shown correctly.
    Many thanks!
