USG20-vpn connected to Google Fiber jack
I just switched to Google Fiber. I connected the Google Fiber Jack directly to the WAN on USG20-vpn but I dont get 1Gbps on devices connected to ports. I only get about 275 Mbps while at the output of the Google Fiber jack I 900+Mbps. Google tech indicated that I should connect the Nest Google Wifi router in between the GF jack to the GF router and then to USG20-vpn. I am asking the forum on any advice to make it work. Do I need to change settings on USG20-vpn? Any advice is greatly appreciated.
For the Specification of USG FLEX 50, please refer here, also has higher models for your consideration.
https://www.zyxel.com/global/en/products/next-gen-firewall/usg-flex-firewall-usg-flex-50/license-and-spec0
Hi, if you would study the characteristics of USG20-VPN, you would know that it is not able to issue more than 350 Mbps on the WAN port.
The
only thing that can do is replace the device with a more productive one.0 -
https://www.zyxel.com/global/en/products/next-gen-firewall/usg-flex-firewall-usg-flex-50/license-and-spec0 -
connecting the Nest Google Wifi router in between the GF jack to the GF router and then the USG20-vpn should solve the problem. Please follow the technician's instructions
-1
- 220 Nebula Ideas
- 603 USG FLEX H Series
- 482 News and Release
