Sonos S1 on Zyxel managed switches: Anyone running a wired or hybrid (wired+wifi) Sonos S1 system
I have real issues getting my Sonos S1 speakers (multiple Play:5 1st Gen) running on my Zyxel managed switches (XMG1930-30HP and XS1930-10HP; both with L3 license and most current 4.80 firmware).
I have multiple VLANs present (but no inter-vlan communication) and IGMP Snooping is activated. Besides that DHCP Server Guard is on, BPDU Flow Control is on, but not much else.
When I try to find the Speakers and add them to the app, they are never found. Also not after factory reset of the Sonos speakers.
Anyone has a successful setup on Zyxel smart/managed switches running with Sonos S1?
(Also the support doc from Zyxel did not help me unfortunately; I also tried the Sonos doc about STP configuration, but also did not work.)
Hi @StefanNetworker,
We have some users who successfully set up Zyxel smart/managed switches running with Sonos devices.
To better help you solve the problem, could you provide a simple topology and the configuration of your switches?
Zyxel Melen0 -
Hi Melen,
Topology is not complicated:
2 Switches (XMG1930-30HP, XS1930-10HP) connected over fiber on the SFP+ ports (port 29). Additionally there is a MikroTik Cloud Core Router 2004-1G-12S+2XS connected over DAC on the 2nd SFP+ port (port 30) on the XMG1930.
No wired loops.
On 3 ports (Port 2,4,6 of the XMG1930) there are 3 Zyxel NWA210AX wifi access points connected which are powered by the switch over PoE and use VLANs as well for the different WIFI SSIDs. All that works fine.
Essentially there are multiple isolated VLANs which realize different isolated networks. No connection between these VLANs. You can see them as completely isolated. They are only accessible over the router for some special cases. Broadcast and multicast domains are only inside the VLANs.
The VLANs span over both switches and also the access points and the MikroTik router as well. That all works well.
On the XMG1930 config below you can also see, that some ports are attached to VLAN 1 (which is my mgmt VLAN where also some equipment for controlling the whole house is in) and VLAN 10 exclusively. That is intentionally.
I have 6 Sonos players in the house: 4x Sonos Play:5, 1x Sonos Port, 1x Sonos Play:1. All running on Sonos current S1 firmware, no way to update, the oldest devices are first gen Sonos Play:5 from 2009, but worked before relocating very well.
Currently the Port, Play:1 and one of the Play:5 is working fine. All wired, WIFI disabled completely, as they anyway could not see each other because of concrete walls with a lot of steel inside.
I bought Smart switches mainly because of their VLAN capabilities, the port speed, PoE and the amount of ports. So of all features the device has, I mainly intentionally activated the VLAN setup. Some other things like IGMP Snooping, DHCP Guard, DHCP Snooping (which is disabled), rate limiting was only as backup measure as I had serios problems when I connected the Sonoses and faced heavy broadcast storms (Sonos created that as they bridged their SonosNet and connected two wired Sonos players on L2 over SonosNet; this is eliminated). This is gone and under control now. Also all the errdisable counters are zero.
For making everything work with Sonos I tried to activate IGMP Snooping, which seems to work fine from what I see in the status messages and also in the pcap traces (collected on my laptop with port mirroring and checked in Wireshark).
I tried to activate MSTP to ensure the spanning tree is controlled by the switch, but I did not succeed with that. See my parallel post.
See here my configuration (export also attached):
; Product Name = XMG1930-30HP ; Firmware Version = V4.80(ACAS.2) | 06/21/2023 ; Service Status = Access L3 ; SysConf Engine Version = 1.2 ; Config last updated = 09:03:55 (UTC+00:00) 2023-09-08 no service-control telnet no service-control ftp no service-control snmp no remote-management 1 service telnet ftp snmpno cloud center discovery vlan 1 name mgmt normal "" fixed 1-12,29-30 forbidden 13-28 untagged 1-28 ip address 192.168.88.2 255.255.255.0 exit vlan 10 name hw-1 normal "" fixed 2,4,6,13-26,28-30 forbidden 1,3,5,7-12,27 untagged 1,3,5,7-28 ip address 192.168.20.2 255.255.255.0 ip address default-gateway 192.168.20.1 exit vlan 11 name hw-2 normal "" fixed 2,4,6,29-30 forbidden 1,3,5,7-28 untagged 1,3,5,7-28 ip address 192.168.21.2 255.255.255.0 exit vlan 30 name hw-guest normal "" fixed 2,4,6,29-30 forbidden 1,3,5,7-28 untagged 1,3,5,7-28 exit vlan 70 name ew normal "" fixed 2,4,6,27,29-30 forbidden 1,3,5,7-26,28 untagged 1,3,5,7-28 exit vlan 80 name ew-guest normal "" fixed 2,4,6,29-30 forbidden 1,3,5,7-28 untagged 1,3,5,7-28 exit igmp-snooping igmp-snooping unknown-multicast-frame drop igmp-snooping vlan 1igmp-snooping vlan 10igmp-snooping vlan 11igmp-snooping vlan 30igmp-snooping vlan 70igmp-snooping vlan 80igmp-snooping querier interface route-domain 192.168.20.2/24 exit interface route-domain 192.168.21.2/24 exit interface route-domain 192.168.88.2/24 exit interface port-channel 1 name "B6 - DG (VID 1 Mgmt Port)" lldp org-specific-tlv dot3 link-aggregation lldp org-specific-tlv dot3 max-frame-size frame-type untagged cpu-protection cause BPDU rate-limit 100 exit interface port-channel 2 name "A11 - EG WZ - Access Point" lldp org-specific-tlv dot3 link-aggregation lldp org-specific-tlv dot3 max-frame-size cpu-protection cause BPDU rate-limit 100 exit interface port-channel 3 name "CCR Mgmt" lldp org-specific-tlv dot3 link-aggregation lldp org-specific-tlv dot3 max-frame-size frame-type untagged dhcp snooping trust dhcp server trust cpu-protection cause BPDU rate-limit 100 exit interface port-channel 4 name "A17 - OG Flur - Access Point" lldp org-specific-tlv dot3 link-aggregation lldp org-specific-tlv dot3 max-frame-size cpu-protection cause BPDU rate-limit 100 exit interface port-channel 5 name "KNX IP Interface" lldp org-specific-tlv dot3 link-aggregation lldp org-specific-tlv dot3 max-frame-size frame-type untagged cpu-protection cause BPDU rate-limit 100 exit interface port-channel 6 name "B5 - DG - Access Point" lldp org-specific-tlv dot3 link-aggregation lldp org-specific-tlv dot3 max-frame-size cpu-protection cause BPDU rate-limit 100 exit interface port-channel 7 name "zimaboard 1 HW vid 1" lldp org-specific-tlv dot3 link-aggregation lldp org-specific-tlv dot3 max-frame-size frame-type untagged cpu-protection cause BPDU rate-limit 100 exit interface port-channel 8 name "VID 1 Mgmt Port" lldp org-specific-tlv dot3 link-aggregation lldp org-specific-tlv dot3 max-frame-size frame-type untagged cpu-protection cause BPDU rate-limit 100 exit interface port-channel 9 name "zimaboard 2 EW vid 1" lldp org-specific-tlv dot3 link-aggregation lldp org-specific-tlv dot3 max-frame-size frame-type untagged cpu-protection cause BPDU rate-limit 100 exit interface port-channel 10 name "Keba Wallbox" lldp org-specific-tlv dot3 link-aggregation lldp org-specific-tlv dot3 max-frame-size frame-type untagged cpu-protection cause BPDU rate-limit 100 exit interface port-channel 11 name "Vallox ValloPlus 510 MV-E" lldp org-specific-tlv dot3 link-aggregation lldp org-specific-tlv dot3 max-frame-size frame-type untagged cpu-protection cause BPDU rate-limit 100 exit interface port-channel 12 name "Fenecon FEMS" lldp org-specific-tlv dot3 link-aggregation lldp org-specific-tlv dot3 max-frame-size frame-type untagged cpu-protection cause BPDU rate-limit 100 exit interface port-channel 13 lldp org-specific-tlv dot3 link-aggregation lldp org-specific-tlv dot3 max-frame-size pvid 10 frame-type untagged cpu-protection cause BPDU rate-limit 100 exit interface port-channel 14 name "B7 - DG Bad - Sonos" lldp org-specific-tlv dot3 link-aggregation lldp org-specific-tlv dot3 max-frame-size pvid 10 frame-type untagged broadcast-limit broadcast-limit 100 multicast-limit multicast-limit 50 mirror mirror dir both cpu-protection cause BPDU rate-limit 100 exit interface port-channel 15 name "A12 - EG WZ - Sonos" lldp org-specific-tlv dot3 link-aggregation lldp org-specific-tlv dot3 max-frame-size pvid 10 frame-type untagged broadcast-limit broadcast-limit 100 multicast-limit multicast-limit 50 mirror mirror dir both cpu-protection cause BPDU rate-limit 100 exit interface port-channel 16 name "B9 - DG SZ - Sonos" lldp org-specific-tlv dot3 link-aggregation lldp org-specific-tlv dot3 max-frame-size pvid 10 frame-type untagged broadcast-limit broadcast-limit 100 multicast-limit multicast-limit 50 mirror mirror dir both cpu-protection cause BPDU rate-limit 100 exit interface port-channel 17 lldp org-specific-tlv dot3 link-aggregation lldp org-specific-tlv dot3 max-frame-size pvid 10 frame-type untagged cpu-protection cause BPDU rate-limit 100 exit interface port-channel 18 lldp org-specific-tlv dot3 link-aggregation lldp org-specific-tlv dot3 max-frame-size pvid 10 frame-type untagged cpu-protection cause BPDU rate-limit 100 exit interface port-channel 19 lldp org-specific-tlv dot3 link-aggregation lldp org-specific-tlv dot3 max-frame-size pvid 10 frame-type untagged cpu-protection cause BPDU rate-limit 100 exit interface port-channel 20 lldp org-specific-tlv dot3 link-aggregation lldp org-specific-tlv dot3 max-frame-size pvid 10 frame-type untagged cpu-protection cause BPDU rate-limit 100 exit interface port-channel 21 lldp org-specific-tlv dot3 link-aggregation lldp org-specific-tlv dot3 max-frame-size pvid 10 frame-type untagged cpu-protection cause BPDU rate-limit 100 exit interface port-channel 22 name "B1 - DG" lldp org-specific-tlv dot3 link-aggregation lldp org-specific-tlv dot3 max-frame-size pvid 10 frame-type untagged cpu-protection cause BPDU rate-limit 100 exit interface port-channel 23 name "B3 - DG - Sonos Port" lldp org-specific-tlv dot3 link-aggregation lldp org-specific-tlv dot3 max-frame-size pvid 10 frame-type untagged broadcast-limit broadcast-limit 100 multicast-limit multicast-limit 50 cpu-protection cause BPDU rate-limit 100 exit interface port-channel 24 name "B2 - DG" lldp org-specific-tlv dot3 link-aggregation lldp org-specific-tlv dot3 max-frame-size pvid 10 frame-type untagged cpu-protection cause BPDU rate-limit 100 exit interface port-channel 25 name Diskstation lldp org-specific-tlv dot3 link-aggregation lldp org-specific-tlv dot3 max-frame-size pvid 10 frame-type untagged cpu-protection cause BPDU rate-limit 100 exit interface port-channel 26 name Diskstation lldp org-specific-tlv dot3 link-aggregation lldp org-specific-tlv dot3 max-frame-size pvid 10 frame-type untagged cpu-protection cause BPDU rate-limit 100 exit interface port-channel 27 name "zimaboard 1 HW vid 70" lldp org-specific-tlv dot3 link-aggregation lldp org-specific-tlv dot3 max-frame-size pvid 70 frame-type untagged cpu-protection cause BPDU rate-limit 100 exit interface port-channel 28 name "zimaboard 2 EW vid 10" lldp org-specific-tlv dot3 link-aggregation lldp org-specific-tlv dot3 max-frame-size pvid 10 frame-type untagged cpu-protection cause BPDU rate-limit 100 exit interface port-channel 29 name "CCR Router Trunk" speed-duplex 10G-full media-type 10g DAC10G lldp org-specific-tlv dot3 link-aggregation lldp org-specific-tlv dot3 max-frame-size frame-type tagged dhcp snooping trust dhcp server trust cpu-protection cause BPDU rate-limit 100 exit interface port-channel 30 name "EW Switch" lldp org-specific-tlv dot3 link-aggregation lldp org-specific-tlv dot3 max-frame-size frame-type tagged cpu-protection cause BPDU rate-limit 100 exit ip name-server 192.168.20.1 mirror-port 22 lacp trunk T1 lacp trunk T1 interface 25 trunk T1 interface 26 spanning-tree mode MSTP spanning-tree auto-path-cost mode short spanning-tree 1 spanning-tree 2 spanning-tree 3 spanning-tree 4 spanning-tree 5 spanning-tree 6 spanning-tree 7 spanning-tree 8 spanning-tree 9 spanning-tree 10 spanning-tree 11 spanning-tree 12 spanning-tree 13 spanning-tree 14 spanning-tree 15 spanning-tree 16 spanning-tree 17 spanning-tree 18 spanning-tree 19 spanning-tree 20 spanning-tree 21 spanning-tree 22 spanning-tree 23 spanning-tree 24 spanning-tree 25 spanning-tree 26 spanning-tree 27 spanning-tree 28 spanning-tree 29 spanning-tree 30 spanning-tree 1 edge-port spanning-tree 3 edge-port spanning-tree 5 edge-port spanning-tree 7 edge-port spanning-tree 9 edge-port spanning-tree 10 edge-port spanning-tree 11 edge-port spanning-tree 12 edge-port spanning-tree 13 edge-port spanning-tree 14 edge-port spanning-tree 15 edge-port spanning-tree 16 edge-port spanning-tree 17 edge-port spanning-tree 18 edge-port spanning-tree 19 edge-port spanning-tree 20 edge-port spanning-tree 21 edge-port spanning-tree 22 edge-port spanning-tree 23 edge-port spanning-tree 24 edge-port spanning-tree 25 edge-port spanning-tree 26 edge-port spanning-tree 27 edge-port spanning-tree 28 edge-port mstp mstp configuration-name LT1 mstp instance 0 vlan 2-9,12-29,31-69,71-79,81-4094 mstp instance 1 vlan 1 mstp instance 2 vlan 10 mstp instance 3 vlan 11 mstp instance 4 vlan 30 mstp instance 5 vlan 70 mstp instance 6 vlan 80 mstp instance 0 priority 4096 mstp instance 1 priority 4096 mstp instance 2 priority 4096 mstp instance 3 priority 4096 mstp instance 4 priority 4096 mstp instance 5 priority 4096 mstp instance 6 priority 4096 mstp instance 1 interface port-channel 1 mstp instance 1 interface port-channel 2 mstp instance 1 interface port-channel 3 mstp instance 1 interface port-channel 4 mstp instance 1 interface port-channel 5 mstp instance 1 interface port-channel 6 mstp instance 1 interface port-channel 7 mstp instance 1 interface port-channel 8 mstp instance 1 interface port-channel 9 mstp instance 1 interface port-channel 10 mstp instance 1 interface port-channel 11 mstp instance 1 interface port-channel 12 mstp instance 1 interface port-channel 29 mstp instance 1 interface port-channel 30 mstp instance 2 interface port-channel 2 mstp instance 2 interface port-channel 4 mstp instance 2 interface port-channel 6 mstp instance 2 interface port-channel 13 mstp instance 2 interface port-channel 14 mstp instance 2 interface port-channel 15 mstp instance 2 interface port-channel 16 mstp instance 2 interface port-channel 17 mstp instance 2 interface port-channel 18 mstp instance 2 interface port-channel 19 mstp instance 2 interface port-channel 20 mstp instance 2 interface port-channel 21 mstp instance 2 interface port-channel 22 mstp instance 2 interface port-channel 23 mstp instance 2 interface port-channel 24 mstp instance 2 interface port-channel 25 mstp instance 2 interface port-channel 26 mstp instance 2 interface port-channel 28 mstp instance 2 interface port-channel 29 mstp instance 2 interface port-channel 30 mstp instance 3 interface port-channel 2 mstp instance 3 interface port-channel 4 mstp instance 3 interface port-channel 6 mstp instance 3 interface port-channel 29 mstp instance 3 interface port-channel 30 mstp instance 4 interface port-channel 2 mstp instance 4 interface port-channel 4 mstp instance 4 interface port-channel 6 mstp instance 4 interface port-channel 29 mstp instance 4 interface port-channel 30 mstp instance 5 interface port-channel 2 mstp instance 5 interface port-channel 4 mstp instance 5 interface port-channel 6 mstp instance 5 interface port-channel 27 mstp instance 5 interface port-channel 29 mstp instance 5 interface port-channel 30 mstp instance 6 interface port-channel 2 mstp instance 6 interface port-channel 4 mstp instance 6 interface port-channel 6 mstp instance 6 interface port-channel 29 mstp instance 6 interface port-channel 30 mstp instance 1 interface port-channel 2 path-cost 6 mstp instance 1 interface port-channel 4 path-cost 6 mstp instance 1 interface port-channel 6 path-cost 6 mstp instance 2 interface port-channel 2 path-cost 15 mstp instance 2 interface port-channel 4 path-cost 15 mstp instance 2 interface port-channel 6 path-cost 15 mstp instance 2 interface port-channel 14 path-cost 10 mstp instance 2 interface port-channel 15 path-cost 10 mstp instance 2 interface port-channel 16 path-cost 10 mstp instance 2 interface port-channel 23 path-cost 10 mstp instance 3 interface port-channel 2 path-cost 6 mstp instance 3 interface port-channel 4 path-cost 6 mstp instance 3 interface port-channel 6 path-cost 6 mstp instance 3 interface port-channel 14 path-cost 10 mstp instance 3 interface port-channel 15 path-cost 10 mstp instance 3 interface port-channel 16 path-cost 10 mstp instance 3 interface port-channel 23 path-cost 10 mstp instance 4 interface port-channel 2 path-cost 6 mstp instance 4 interface port-channel 4 path-cost 6 mstp instance 4 interface port-channel 6 path-cost 6 mstp instance 5 interface port-channel 2 path-cost 6 mstp instance 5 interface port-channel 4 path-cost 6 mstp instance 5 interface port-channel 6 path-cost 6 mstp instance 6 interface port-channel 2 path-cost 6 mstp instance 6 interface port-channel 4 path-cost 6 mstp instance 6 interface port-channel 6 path-cost 6 mstp instance 4 interface port-channel 2 priority 64 mstp instance 4 interface port-channel 4 priority 64 mstp instance 4 interface port-channel 6 priority 64 mstp interface port-channel 1 edge-port mstp interface port-channel 3 edge-port mstp interface port-channel 5 edge-port mstp interface port-channel 7 edge-port mstp interface port-channel 8 edge-port mstp interface port-channel 9 edge-port mstp interface port-channel 10 edge-port mstp interface port-channel 11 edge-port mstp interface port-channel 12 edge-port mstp interface port-channel 13 edge-port mstp interface port-channel 17 edge-port mstp interface port-channel 18 edge-port mstp interface port-channel 19 edge-port mstp interface port-channel 20 edge-port mstp interface port-channel 21 edge-port mstp interface port-channel 22 edge-port mstp interface port-channel 24 edge-port mstp interface port-channel 25 edge-port mstp interface port-channel 26 edge-port mstp interface port-channel 27 edge-port mstp interface port-channel 28 edge-port mstp interface port-channel 29 edge-port timesync server 1.pool.ntp.org timesync ntp bcp-transparency storm-control snmp-server version v3 snmp-server get-community sk24 snmp-server set-community sk24 snmp-server trap-community sk24 service-control http 80 30 service-control telnet 23 15 dhcp option profile everything circuit-id slot-port vlan hostname remote-id mac dhcp snooping vlan 1,10-11,30,70,80dhcp snooping vlan 1,10-11,30,70,80 option profile everything rmon statistics etherstats 1 port-channel 1rmon statistics etherstats 2 port-channel 2rmon statistics etherstats 3 port-channel 3rmon statistics etherstats 4 port-channel 4rmon statistics etherstats 5 port-channel 5rmon statistics etherstats 6 port-channel 6rmon statistics etherstats 7 port-channel 7rmon statistics etherstats 8 port-channel 8rmon statistics etherstats 9 port-channel 9rmon statistics etherstats 10 port-channel 10rmon statistics etherstats 11 port-channel 11rmon statistics etherstats 12 port-channel 12rmon statistics etherstats 13 port-channel 13rmon statistics etherstats 14 port-channel 14rmon statistics etherstats 15 port-channel 15rmon statistics etherstats 16 port-channel 16rmon statistics etherstats 17 port-channel 17rmon statistics etherstats 18 port-channel 18rmon statistics etherstats 19 port-channel 19rmon statistics etherstats 20 port-channel 20rmon statistics etherstats 21 port-channel 21rmon statistics etherstats 22 port-channel 22rmon statistics etherstats 23 port-channel 23rmon statistics etherstats 24 port-channel 24rmon statistics etherstats 25 port-channel 25rmon statistics etherstats 26 port-channel 26rmon statistics etherstats 27 port-channel 27rmon statistics etherstats 28 port-channel 28rmon statistics etherstats 29 port-channel 29rmon statistics etherstats 30 port-channel 30pwr mode consumption errdisable recovery cause BPDU errdisable recovery cause IGMP errdisable detect cause ARP errdisable detect cause BPDU errdisable detect cause IGMP errdisable detect cause ARP mode rate-limitation errdisable detect cause BPDU mode rate-limitation errdisable detect cause IGMP mode rate-limitation wizard ignore
Any ideas, what I could do or change?
Reply to the problem “When I try to find the Speakers and add them to the app, they are never found.”
After checking the configuration, it does not have much problem except the MSTP. Please check the parallel post to set it up.
Moreover, is the device that uses the Sonos APP in the same VLAN as your Sonos devices? If yes, this is more likely the problem with Sonos APP. You might need to find Sonos support for help.P.S. Sonos APP uses SSDP (broadcast and mulitcast(239.255.255.250)) to scan the Sonos devices.
Zyxel Melen0 -
I have Sonos S1 with both wired and wireless Sonos devices (9 total) set up with Zyxel switches (Combination of XGS3700, GS2210, GS1910, and GS1900).
I have found the way to get them to work is to have all of the Sonos devices and any controller (mobile device or desktop computer) on the same vlan. Set up the non-wired Sonos devices to use SonosNet. Then set up STP, not MSTP or RSTP on the ports the wired Sonos devices are connected to. Be sure your switch is set up as the root bridge.
Yes, for me also everything is on same VLAN 10. All players and the app. I wanted to avoid multicast routing or cross-VLAN communication exactly to not make it unnecessarily complicated. Also that works well for the working players.
I can now also confirm, that STP works with MSTP with the working players. I see on the Sonos Web interfacehttp://zp-ip-address.local:1400/support/review (output of: /usr/sbin/brctl showstp br0 ) that the switch running MSTP is taken properly as the root bridge, all ports where players are connected are up and forwarding. That looks good.
But unfortunately even after having STP right as far as I can tell, the non connecting players still are not found. Damn it.
I also already have thread open on Sonos forum, but nothing helpful so far from there. Challenging.
Many thanks for all the help!
- 441 Beta Program
- 533 USG FLEX H Series
- 334 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 461 News and Release
