SSL VPN not working
StevenB
StevenB Posts: 3 image  Freshman Member
Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula First Comment
edited April 2021 in Security
I've been setup an SSL vpn to my zyxel USG 60. I can establish a connection with the Secu-extender, but I can't reach a device on my LAN1 network....even ping will not work...
Can anyone help me with this issue???
  • Alfonso
    Alfonso Posts: 257 image  Master Member
    Hi  @StevenB
    Welcome to the forum.
    I suggest verifying if "pings" reach your internal servers.
    Try to sniff icmp packets on one of your servers while a ssl vpn user is "pinging" the server.
    Regards
  • StevenB
    Hi Alfonso,
    There are no clients reachable... I tryed almost everything but nothing will work...
  • Zyxel_Emily
    Hi @StevenB,
    We fix some SSL VPN related issues in the latest firmware.
    The firmware is sent to you via private message.
    Upgrade your USG60 to this version and check if SSL VPN client is able to reach devices in LAN1.
  • Franki80
    Franki80 Posts: 6 image  Freshman Member
    First Comment Seventh Anniversary
    Hi. I have the exact! same issue. Also tried upgrading the USG60 to latest FW v4.32(AAKZ.0) with no luck...
  • Zyxel_Chris_H
    Zyxel_Chris_H Posts: 28 image  Freshman Member
    First Answer First Comment Friend Collector
    Hi @Franki80
    This issue is fixed in latest firmware,
    The latest firmware will be sent to you in the private message. Please check your inbox.
  • ZdenekB
    ZdenekB Posts: 10 image  Freshman Member
    Hi a have same problem on USG20-VPN - firmware 4.32 (ABAQ.0). Is there a firmware fix for this model?
  • Franki80
    Hi.
    Newest firmware fixed it for my USG60W.
  • Zyxel_Chris_H
    Hi @ZdenekB
    The latest USG20-VPN firmware will be sent to you in the private message. Please check your inbox
