Zyxel security advisory for the key management vulnerabilities of WPA2 protocol
Zyxel
is aware of the recently found key management vulnerabilities of the WiFi Protected
Access II (WPA2) security protocol, as identified in US-CERT vulnerability note VU#228519, with the vulnerability IDs listed in table 1.
What are the vulnerabilities?
These vulnerabilities affect wireless products that connect to WiFi networks in different ways, depending on the role of products as WiFi clients or servers, as described in table 1 below.
Table 1.
Type of attack | CVE IDs | Devices impacted |
4-way handshake | WiFi clients | |
Group-key handshake | WiFi clients | |
802.11r Fast-BSS Transition (FT) | Access points | |
Peer-key handshake | WiFi clients |
It is important to note that an attacker has to be physically nearby and is within the wireless range to exploit these weaknesses.[1]
Please see: https://www.krackattacks.com/#details for more technical information.
How are Zyxel resolving the vulnerabilities?
At Zyxel we treat security as a top priority and we have conducted a thorough investigation and identified a list of vulnerable products within their warranty and support period, as shown in table 2 below. For products not listed, they are not affected to the attacks either because they are not designed to act as WiFi clients, do not support 802.11r Fast-BSS Transition handshake, or do not support peer-key handshake by default.
We are now co-working with WiFi chipset vendors to create a solution, and the patch firmware will be available in the next few weeks or even sooner, provided WiFi chipset vendors will release their patches much earlier.
Please refer to table 2 for the detailed release schedule.
Table
2
Devices Impacted |
Series/Model |
Hotfix Availability |
Standard Availability |
WiFi Clients |
NWA1100-NH |
31-Dec 2017 |
Feb 2018 or sooner |
Access Points |
NWA5301-NJ* |
16-Nov 2017 |
NWA5123-AC* |
16-Nov 2017 |
WAC6103D-I* |
16-Nov 2017 |
WAC6500 series* |
16-Nov 2017 |
* The above Access Points (NWA5301-NJ, NWA5123-AC, WAC6103D-I, WAC6500 series) are only affected when managed by NXC2500/5500 with 802.11r enabled. Note that when the mentioned Access Points in standalone mode are not affected because 802.11r is not supported in this mode and therefore, there is no hotfix/solution required. So the available hotfix we release is for NXC2500/NXC5500.
Please click on the link below to download the hotfix for NXC2500/NXC5500.
What should I do now to protect myself against the vulnerabilities?
As
mentioned previously - It is important to note that an attacker has to be
physically nearby and is within the wireless range to exploit these weaknesses. As our
Business class Access Points support the 802.11r Fast-BSS Transition (FT)
handshake, devices supporting this feature are listed in the vulnerability list
(table 2). By default, the 802.11r is not enabled in Zyxel Products or
Controllers; and the majority of Zyxel customers will not be affected.
For customers who have enabled 802.11r, who are concerned about the security risks, they should disable the 802.11r feature to prevent an attack from taking place. Once the Hotfix has been released, clients wishing to use the 802.11r feature are advised to update as soon as possible to ensure the vulnerability does not affect the security of their network.
For more information and technical details regarding the vulnerabilities please see below references:
1. US-CERT VU note: https://www.kb.cert.org/vuls/id/228519/
2. Disclosure by by Mathy Vanhoef of imec-DistriNet of KU Leuven: https://www.krackattacks.com/
Zyxel will update this advisory when more information is available.
I have got nwa1100-nh ap but known issues not resolved long time.www.zyxel.comKnown Issue:1.[Spec issue] Users will not be able to select channel when wireless interface is disabled.2.[Spec issue] The log should not be cleared after AP reboot.
3.[Spec issue] When device operating in client mode , LAN port device will not get IP address when the DHCP server uses unicast.4. Sometimes Telnet service is not available after changing secure access control settings on AP.
Hi @kidalabama
Thanks for your sharing. Here is our reply for each item.
1. When the interface is enable, we can select the channel.
2. We support syslog server and email. You can send out the logs via the settings.
3. Almost of the servers are using broadcast now. You can use static IP address if needed.
4. NXC and AP support GUI. We can configure all the settings via GUI. Do you have any specific usage which must under Telnet?
By the way, since this place is for new and release, you can post your comment at discussions.
Here is the link.
https://businessforum.zyxel.com/categories/wlan-discussions
Thanks.
Joslyn0 -
3. I DON'T WANT USE STATIC IP.I WANT USE DHCP AND NEW FIRMWARE WITH SOLVED PROBLEMS. 2.13 firmware.PLEASE READ2.12 FIRMWARE KNOWN ISSUE.
I deployed several NWA1100-NH in my environment. All of them are DHCP clients; however, I did not meet the issue as the spec described. I thought most of the DHCP servers are using broadcast, not unicast. If you meet the DHCP server using unicast, I thought applying static IP address is also a good idea because it is easy to manage APs. No worry about losing the DHCP table. Or maybe use another DHCP server with broadcast?0
i am using as client mode. zyxel is detected this problem and writing new firmware info as described KNOWN ISSUES. but not created new firmware with solved known issues. zyxel=problem.
We know the issue; however, there is no fix plan so far. So, we have two suggestions for you to resolve this kind of situation.
1. Use static IP address for each client.
2. Use a DHCP server with broadcast flag.
Apologize to cause you any inconvenience.
Thanks.
Joslyn
Please add fix plan. I am already added static ip but this is very hard.
We don't have fix plan for this issue. Please use our suggestion as workaround.
Apologize to cause your any inconvenience.
Thanks.
Joslyn0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
