SSL VPN SecuExtender 4.0.3.0 not working
dennidalpos
dennidalpos Posts: 2  Freshman Member
edited April 2021 in Security
After installing lastest vpn software (4.0.3.0) it connect but cannot reach computers.
USG110 with lastest firmware (
V4.32 AAKY.0)
  • Zyxel_Chris_H
    Zyxel_Chris_H Posts: 28  Freshman Member
    First Answer First Comment Friend Collector
    edited December 2018
    HI @dennidalpos
    According your description, it’s probably your PC didn’t get SSL VPN IP when you connect successfully.
    You have to change the assigned pool to  “SUBNET” in your SSL_VPN Setting.
    Configuration -> SSL VPN -> Access Privilege -> Edit ->  Create new Object -> Address
    In the Address Type, select “SUBNET”
    Setting Result:
  • dennidalpos
    WORKING.
    i dont know why dont work with RANGE instead SUBNET. Mine was in RANGE and setting up a pool of IP instead all SUBNET.
    Just with this last update it doesnt work anymore.
    Thanks anyway!
  • Zyxel_Chris_H
    Hi ! @dennidalpos
    This issue is fixed in latest firmware,
    The latest firmware will be sent to you in the private message. Please check your inbox.
  • michael3767
    michael3767 Posts: 2  Freshman Member
    can you send me latest firmware? I too have the same issue as original poster usg110 with latest firmware using secuextender 4.0.3.0 same issue doesn't work with range
  • Zyxel_Emily
    Zyxel_Emily Posts: 1,417  Zyxel Employee
    The firmware is sent to you via private message.
  • ToDv
    ToDv Posts: 1  Freshman Member
    Hi, I have the same issue with Zywall 110, Firmware Version:V4.32(AAAA.0). Can you please send me the firmware or should I use the older 4.0.2.0 ? Thanks...
  • Zyxel_Charlie
    Zyxel_Charlie Posts: 1,034  Zyxel Employee
    @ToDv
    I private message the firmware to you. Please has a check.
    Charlie
