Anybody else seeing App Patrol statistics re-enabling after router reboot?
To improve performance of our FLEX 500 I have disabled App Patrol Statistics under Monitor tab > Security Statistics > App Patrol. I have now disabled it at least twice, and noticed that it keeps re-enabling itself. I have our router set to restart once a week and I believe it is coinciding with that. After turning it off, I have checked on it for several days and it is off and then after the restart I find it re-enabled. Using latest available firmware version.
I performed a test on USGFLEX 500 v5.37, and after the scheduled reboot, the option remains disabled.
Could you provide remote access or configuration via private message? I would like to check your configuration, thanks.0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 345 Security Ideas
- 482 News and Release
