IKE VPN Certificate renewal on a USG 210
Hopefully someone can help with this.
I have an IKEv2 remote access VPN setup using a certificate created using the Zyxel. It works fine at the moment but when I replace the certificate it stopped working.
I created a new certificate using the Zyxel with the same settings as the previous one. Added it to my computers Trusted Certificates. I then change to the new certificate in the IKE VPNs gateway settings. it then fails to authenticate.
have I missed something? I haven't been able to reboot the Zyxel, will it only set after a reboot?
David
Hi @DaviD42,
Which IKEv2 client are you using? Zyxel IPSec VPN client or native Windows client?
Native Windows.
Hi @DaviD42,
In the VPN gateway, select the new created certificate.
Export the certificate without password and import it to the laptop.
Thanks,
Thats what I tried. Exported no password, imported to Trusted Certificates in windows. changed the certificate in the VPN Gateway.
But it then stops working. If i change the certificate back it works fine again.
Hi @DaviD42,
Please send the remote access information of your USG210 to me in private message. I'll check the configuration and establish IKEv2 to your USG210 to check the symptom. Thanks!
- 435 Beta Program
- 176 Nebula Ideas
- 425 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
