Security advisor pop-up
My question may be simple, but I can't find the pop-up window with the recommended change of ports and geolocation that appeared after logging into the GUI recently.
After making the changes, the window no longer appears and I don't know how to make it appear again.
Can anyone help? I remember that in GUI there was a link to it but now cannot find it.
Best Answers
Hello @AdmineXant
Welcome to the Zyxel community. Please refer to this FAQ article: How to trigger " Security Check for Web Interface "function ? If the firewall detects any source IP can access your WAN interface and will pop out this page.
Such as this security policy :
Thanks.
Hello @AdmineXant
OK, you are welcome. Thanks.
Hello @AdmineXant
Thanks.
Thank You very much.
Hello @AdmineXant
how to make the window reappear when we have selected the item "Please remove me: NEVER"?
Thank you
Hi @lorenko,
Have you tried to disable the security policy that trigger "Security Check for Web Interface "function?
If yes, try to follow the FAQ to trigger it out. Hope it helps.
Zyxel Melen0
- 237 Nebula Ideas
- 6.8K Security
- 744 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
