VPN setup/policys
Franki80
Franki80 Posts: 6 image  Freshman Member
First Comment Seventh Anniversary
edited April 2021 in Security
Hi.
I have set up SSL VPN on a USG60W and are struggeling with some connections
I have setup users/pools/polocy and users are able to connect with the SecuExtender, but not able to ping/RDP anything on the local LAN.
Users get connected and gets client IP. Route should also be correct (its the internal LAN subnet)
Any ideas?
