VPN50 Firewall Default Config
RonAllen
RonAllen Posts: 9 image  Freshman Member
I have a question about the default policy "WAN to Zywall" which by default is enabled and allowing all traffic. Is there any reason why I should keep this enabled if I have higher level policies allowing the incoming traffic I need? What will happen if I disable it?
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,392 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    Hi @RonAllen
    Yes, as PeterUK mentioned, the default WAN_to_Device security policy allows VPN-related traffic to enter the firewall.
    PeterUK Posts: 4,502 image  Guru Member
    It mostly there for allowing VPN
  • RonAllen
    Thanks for your reply Peter. So there is minimal risk for denying incoming traffic for this rule.
  • Zyxel_Jeff
    Hi @RonAllen
