VPN setup/policys
Hi.
I have set up SSL VPN on a USG60W and are struggeling with some connections
I have setup users/pools/polocy and users are able to connect with the SecuExtender, but not able to ping/RDP anything on the local LAN.
Users get connected and gets client IP. Route should also be correct (its the internal LAN subnet)
Any ideas?
Any ideas?
Hi @Franki80
Welcome to the forum.
It looks there is a problem with SSL VPN
https://businessforum.zyxel.com/discussion/comment/5669#Comment_5669
It looks it can be solved upgrading the software.
Regards
Hi. No luck with software upgrade. I have now upgraded to v4.32(AAKZ.0) and rebooted. Still the same issue. Strange...all policy's seems OK as well.0
HI @Franki80
This issue is fixed in latest firmware,
The latest firmware will be sent to you in the private message. Please check your inbox.0 -
Hi.
That works! Thanks a lot!
- 603 USG FLEX H Series
- 481 News and Release
