Site-to-Site Force Tunnel
Routing. And firewall/policy rules.
Hi @KITNIT,
Here’s an example setup for this environment;
In USG60’s configurations you need to add following policy routes;
(Configuration > Network > Routing > Policy Route)
1- With the source address of 10.10.10.0/24 will be forwarded to IPSec tunnel with the name of IKEv2
2- Any traffic to 20.20.20.0/24 will be forwarded to IPSec tunnel with the name of IKEv2
3- Any traffic from 20.20.20.0/24 will be forwarded to SYSTEM_DEFAUL_WAN_TRUNK
You will also need to add a Security Policy rule;
(Configuration > Security Policy > Policy Control)
Allow the traffic that comes from IPSec_VPN.
In USG40’s configurations you need to add following policy routes;
1- With the source address of 20.20.20.0/24 will be forwarded to IPSec tunnel with the name of IKEv2
2- Any traffic to 10.10.10.0/24 will be forwarded to IPSec tunnel with the name of IKEv2
3- Any traffic from 10.10.10.0/24 will be forwarded to SYSTEM_DEFAULT_WAN_TRUNK
I have to make such a site-site VPN, my question is, shouldn't the routings be added exactly the reciproc way around? …what is in USG40 to USG60 and vica-versa?
f I understand correctly, this is necessary in case of the two sites, only one site can "go to the internet"?0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
