Zywall USG 110: LAG/Port-Channel ?
Hello everybody,
is it possible to configure a LAG/Port Channel on a Zywall USG 110 ?
I have the option to put 2 Ports on the same LAN like this:
But I have some perfomance trouble, my switch that is connected cant handle it right with this configuration.
We use a Ubiquiti Unifi switch that have the possibility to use LAG/PC.
Hi @Bobby
USG 110 does not support LAG(Link Aggregation Group)
If you need to use LAG, you can consider following models:
ZyWALL 310, ZyWALL 1100, USG 310, USG 1100, USG 1900
Okay Thanks for the information, for this feature we wont buy a new hardware..
Do i have a way to manage the traffic if i put the both ports on the LAN1 ?0 -
Hi @Bobby
You can use BWM to manage the traffic by following settings.(Configuration -> BWM )1. Click “Enable BWM”
2. Click “Add” Button to add policy
3. In Criteria zone, You can select the LAN 1 in “incoming interface” or “Outgoing interface“to manage LAN 1 traffic.
4. In Bandwidth Shaping zone, Input the “Guaranteed Bandwidth” and “Maximum Bandwidth” for Inbound and Outbound Traffic.
5. Press “OK” Button, and then Press “Apply” Button.
Hi Chris,
Thanks for the Information, works fine.
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
