SOLVED. - USG40W login security problem.
Thaiger
Thaiger Posts: 6 image  Freshman Member
edited April 2021 in Security
I am new to this advanced firewall and this community, please be pacient with me, and sorry for my English as I am from Denmark.
I need to login to my USG40W, but I meet this problem at any browser (IE, Firefox, Chrome). Please see pictures.
I know it's a security problem, but how do I gain access, and can I gain access without the resource  ?!
The pic says the ip is correct, but the "resource is not found" ?!
I am not familiar with ssh/telnet login, so please help me another graphical way.
Thanks in advance :-)
Kind regards
Thaiger
  • Alfonso
    Alfonso Posts: 257 image  Master Member
    edited December 2018
    Hi @Thaiger
    Welcome to the forum.
    I recomend to watch the following videos, they maybe help you.
    https://www.youtube.com/watch?v=KCvjVgAfjRY
    https://www.youtube.com/watch?v=qQWH_vtj_5Q
    Best regards
  • Zyxel_Chris_H
    Zyxel_Chris_H Posts: 28 image  Freshman Member
    First Answer First Comment Friend Collector
    Hi @Thaiger
    Perhaps the HTTPS service was disabled (Configuration -> System -> WWW -> Service Control). You can enter into Console Mode, and enter following Commands to enable HTTP Service
    1. configure terminal
    2. ip http secure-server
    3. write
    4. exit
  • Thaiger
    Hi @Zyxel_Chris_H
  • Thaiger
    Hi @Alfonso,
  • Alfonso
    Hi @Thaiger
    Do the videos help you to reactivate web interface?
    Cheers
  • Thaiger
    1) I don't get the login pic as in in the video.
    2) As my PC's don't have any serial port I can't use the serial access via Tera Term.
    So I probably need telnet/ssh/? via tcp/ip ?!
    3) I have installed putty
    4) I type; (I don't type "-enter" it's info for you)
    admin -enter
    1234 -enter
    Etc pls see pic, as I get command not found !
    @Zyxel_Chris_H
    @Alfonso
    I look forward to your further help, please
    By the way, i dont need any settings that may be setup/stored on it.
    So if a factory reset is easy (and will solve the problem), then please tell me if its enougt just to reset via the reset button on the back  ?
    Or if factory reset demands a specifik combination  !
  • Thaiger
  • Thaiger
    @Zyxel_Chris_H
    Super thanks, finally I am in :-)
    I typed:
    configure terminal
    no ip http secure-server
    write
    no ip http secure-server force-redirect
    write
    exit
    Some of these commands may be right, some wrong, but I came inside (had to use Internet Explorer)
    I am realy happy for your @Zyxel_Chris_H and @Alfonso help.
    Marry Christmas and Happy New Year
