SSL VPN SecuExtender 4.0.3.0 not working
dennidalpos
After installing lastest vpn software (4.0.3.0) it connect but cannot reach computers.
USG110 with lastest firmware (V4.32 AAKY.0)
HI @dennidalpos
According your description, it’s probably your PC didn’t get SSL VPN IP when you connect successfully.
You have to change the assigned pool to “SUBNET” in your SSL_VPN Setting.
Configuration -> SSL VPN -> Access Privilege -> Edit -> Create new Object -> Address
In the Address Type, select “SUBNET”
Setting Result:
WORKING.
i dont know why dont work with RANGE instead SUBNET. Mine was in RANGE and setting up a pool of IP instead all SUBNET.
Just with this last update it doesnt work anymore.
Thanks anyway!0 -
Hi ! @dennidalposThis issue is fixed in latest firmware,
The latest firmware will be sent to you in the private message. Please check your inbox.0 -
can you send me latest firmware? I too have the same issue as original poster usg110 with latest firmware using secuextender 4.0.3.0 same issue doesn't work with range0
Hi, I have the same issue with Zywall 110, Firmware Version:V4.32(AAAA.0). Can you please send me the firmware or should I use the older 4.0.2.0 ? Thanks...
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
