GS-1920 VLAN with link aggregation
Hi @otto001 ,
As per your previous information, the internet router is connected to Port 21, whether it's the previous switch GS1900-24 or the new switch GS1920-48, and it's not capable of handling VLANs. To enable the traffic from the internet router to be forwarded to the server, please follow these steps for Port 21:
- PVID = 10 (You can configure this setting under Advanced Application > VLAN > VLAN Configuration > VLAN Port Setup)
- For VLAN1, set it to "Normal"
- For VLAN10, configure it as a "Fixed" without TX Tagging
By configuring Port 21 as described, you'll ensure that the traffic from the internet router is correctly directed to the server.
Kay
- 603 USG FLEX H Series
- 481 News and Release
