Error "Configure AAA group has failed: group is in use" when trying to remove
TriLanSupport
TriLanSupport Posts: 15 image  Freshman Member
Have an issue with an AD Server config on a USG that is not showing any references but won't let me remove it. I created an additional entry that is using the same details as a test. Now when I go to remove it I get an error. Suggestions?
  • Zyxel_James
    Zyxel_James Posts: 809 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate 100 Answers
    Hello @TriLanSupport
    It seems you still have references to the create AD server provided
    So you sure the created profile does not have any references? If so, could you provide remote access or configuration for further checking? thanks.
  • TriLanSupport
    Yes I do still have references to the created AD service - however the references search provides no details suggesting there are no references. I will continue to look but perhaps could you provide some guidance on where to check for any hidden references?
