NWA55AXE SNMP
I know this question already came: Is it possible to enable snmp on the NWA55AXE? SNMP seems to be already implemented. When I connect via SSH and get the status from SNMP, I get the following:
Router(config)# show snmp status
active : no
port : 161
version : v2c
contact : support@zyxel.com.tw
get community : public
set community : private
trap : yes
informs : yes
trap host : 172.16.1.27
trap community: public
wireless trap : yes
Hello @focmb
Currently, the NWA55AXE is tailored for small business environments and does not include SNMP support.
To better assist you, could you please share more details about why SNMP is important for your specific use case? Understanding your requirements will enable us to recommend a device or feature set that aligns closely with your needs.
Best Regards,
Nami
I would like to monitor all of my lan devices. All switches, the server and the ups have snmp and are integrated inthe monitoring system. Only the Zyxel AP is missing and I think, snmp should be a standard feature. But now i will change the ap firmware to openwrt and will test if there is a snmp implementation (the NWA55axe is supported by openWRT).
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
