Error "Configure AAA group has failed: group is in use" when trying to remove
TriLanSupport
in Security
Have an issue with an AD Server config on a USG that is not showing any references but won't let me remove it. I created an additional entry that is using the same details as a test. Now when I go to remove it I get an error. Suggestions?
Hello @TriLanSupport
It seems you still have references to the create AD server provided
So you sure the created profile does not have any references? If so, could you provide remote access or configuration for further checking? thanks.0 -
Yes I do still have references to the created AD service - however the references search provides no details suggesting there are no references. I will continue to look but perhaps could you provide some guidance on where to check for any hidden references?
- 3K Nebula
- 223 Nebula Ideas
- 6.6K Security
- 633 USG FLEX H Series
- 355 Security Ideas
- 85 Switch Ideas
- 54 Wireless Ideas
- 301 Service & License
- 493 News and Release
- 109 Security Highlight
