GS2210-8HP - Factory Reset
I am repurposing a GS2210-8HP that was take out of service. I do not have the user name/password. I want to do a factory reset.
I looked in the manual but it seems I need a "factory default configuration file". I do not have one available. Where can I get one or is there an easier way to reset the switch.
Hi @imaohw,
Welcome to Zyxel community!
Before you reset your switch to factory defult, you may need the following:- A PC with terminal emulation software(Ex: Teraterm).
- Console cable.
- Factory default configuration(.rom).
Then you may follow the user's guide or FAQ Link to reset your switch to factory default.
Hope it helps.
Jason0 -
Same problem here. The rom files are not available anymore.
I own this brick and would be great to have the rom - since, ridiculously, there is no "reset to factory defaults" procedure available, without serial cable rom upload.
What could we do to get the rom?0 -
Please provide the rom file, since there is not available online anymore.0
Hi @Mike_Mike,
May I know which switch model that you need the ROM file?
Is it GS2210-8HP or other GS2210 model?Zyxel Melen0 -
Zyxel_Melen said:Hi @Mike_Mike,
Is it GS2210-8HP or other GS2210 model?0 -
Hi @Mike_Mike,
Here is the ROM file of GS2210-8HP.
If there has any other question, you may feel free to ask.Zyxel Melen0 -
Hi Zyxel Melen
I have the same problem with my GS2200-24 switch can you please supply the configuration files for this model as I cant find them anywhere.
Thank you.
- 415 Beta Program
- 2.4K Nebula
- 146 Nebula Ideas
- 96 Nebula Status and Incidents
- 5.7K Security
- 252 USG FLEX H Series
- 270 Security Ideas
- 1.4K Switch
- 72 Switch Ideas
- 1.1K Wireless
- 40 Wireless Ideas
- 6.4K Consumer Product
- 249 Service & License
- 387 News and Release
- 84 Security Advisories
- 29 Education Center
- 3.5K FAQ
- 73 Security Highlight
