gs1900 8HP after firmware upgrade I can't login in with admin 1234 any longer - help!
Hi, thanks for the reply. I went from V1.6 to V2.7.
I have not changed the default admin login/password
Hi @Classicm,
Since GS1900-8HP doesn’t have V1.6 firmware, I assume you were using V2.60 firmware. So, I tried to reproduce this problem from V2.60(Patch1) to V2.70(Patch5), V2.60(Patch2) to V2.70(Patch5), V2.60(Patch3) to V2.70(Patch5), V2.60(Patch4) to V2.70(Patch5), but I can still use admin/1234 to log in.
To fix your problem, please press the reset/restore button in the front panel for 10 seconds to factory default it.
Zyxel Melen0
- 439 Beta Program
- 2.8K Nebula
- 198 Nebula Ideas
- 6.3K Security
- 484 USG FLEX H Series
- 319 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 451 News and Release
- 4.3K FAQ
- 93 Security Highlight
