Forwarding ports with intermediate router
Enrique_C
Enrique_C Posts: 7 image  Freshman Member
edited October 2023 in Security
Hello, our scenario is:
Internet —— Router (192.168.0.1) —— (192.168.0.2) Zywall USG20 (192.168.9.1) ———- PC (192.168.9.100)
In our router we have create a forwarding rule - all external traffic by 1433 port is redirected to the Firewall wan_IP 192.168.0.2
We need to redirect all the external traffic through 1433 TCP port to PC. Can you help us to configure the firewall-side?
Thanks in advance
    PeterUK Posts: 4,522 image  Guru Member
    edited October 2023
    If the 1st router has static route you can do a more advanced way of forwarding.
    Or to double NAT make NAT rule for Virtual Server
    incoming WAN of USG20
    External 192.168.0.2
    internal 192.168.9.100
    port TCP 1433
    Then a firewall rule from WAN to LAN for that port
  • Enrique_C
    Thank you, we have created a NAT Rule …
    External IP - 192.168.0.2
    Internal IP - 192.168.9.100
    And create a Policy …
    But cotinues closed …
    Thank you
    Your firewall Policy is wrong needs to be the zone your server is on like LAN1 not Zywall
  • Zyxel_Kevin
    Zyxel_Kevin Posts: 988 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Sales Associate 100 Answers 500 Comments
    Hi @Enrique_C ,
    Greeting Forum , thank PeterUK.
    Please kindly change your zone where internal server located. (not zywall)
    Thank you
  • Enrique_C
    Hi PeterUK,
    We changed to LAN1
    But it continues blocked
    Thank you
  • Zyxel_Kevin
    Hi @Enrique_C ,
    Please kindly provide your config by Private Message.
    I will check the configuration.
    Thank you
    Does your ISP allow port 1433 ?
