Forwarding ports with intermediate router
Hello, our scenario is:
Internet —— Router (192.168.0.1) —— (192.168.0.2) Zywall USG20 (192.168.9.1) ———- PC (192.168.9.100)
In our router we have create a forwarding rule - all external traffic by 1433 port is redirected to the Firewall wan_IP 192.168.0.2
We need to redirect all the external traffic through 1433 TCP port to PC. Can you help us to configure the firewall-side?
Thanks in advance
If the 1st router has static route you can do a more advanced way of forwarding.
Or to double NAT make NAT rule for Virtual Server
incoming WAN of USG20
External 192.168.0.2
internal 192.168.9.100
port TCP 1433
Then a firewall rule from WAN to LAN for that port
Thank you, we have created a NAT Rule …
External IP - 192.168.0.2
Internal IP - 192.168.9.100
And create a Policy …
But cotinues closed …
Thank you
Your firewall Policy is wrong needs to be the zone your server is on like LAN1 not Zywall
Hi @Enrique_C ,
Greeting Forum , thank PeterUK.
Please kindly change your zone where internal server located. (not zywall)
Thank you
Hi PeterUK,
We changed to LAN1
But it continues blockedThank you
Hi @Enrique_C ,
Please kindly provide your config by Private Message.
I will check the configuration.
Thank you
Does your ISP allow port 1433 ?
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
