SecuReporter: user always unknown. How to identify?
And based on the first question: can the USG translate/resolve the source IP to a DNS record? Because now we have to manually lookup the computers' source name every time we want to know more about a certain source IP.
Hi @MpDay,
The username from AD server is able to be shown on the SecuReporter.
Here is the example for your reference.
In SSL VPN, move “ad-users” to Selected User.
Enable “Force all client traffic to enter SSL VPN tunnel”. It means SSL VPN users access the Internet through the ZyWALL.
Create a content filter profile.
Remember to log all pages.
Create a new security policy rule and apply the content filter profile to this rule.If you use default Auth. Method, remember to add group ad to default method.
SSL VPN is connected. The user type of “AMY” is ad-users.
On SecuReporter, the ad-user “AMY” is shown on the list.
For users in LAN, you need to enable web authentication in order to see usernames on SecuReporter instead of “unknown” user.
Same question from a different angle:
Using the ATP800 to both manage vLANs to separate departments and bandwidth manage public IP addresses that are derived from the WAN.
The WAN has multiple public IPs, which are fed to routers after the ATP800 via port 12, set as "general" and in the DMZ.
Any traffic via this interface is marked "Unknown", so not much use in a report.
Can the individual IPs be reported on?0 -
idea -> die?
Hi @halter ,
All the ideas in the “ideas” category are valuable to us. And the “like” number is an important evaluation factor. The more “like” this idea can get, the more opportunity it will come true in our future design.
- 431 Beta Program
- 2.6K Nebula
- 165 Nebula Ideas
- 6K Security
- 364 USG FLEX H Series
- 292 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 262 Service & License
- 407 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
