IOS IKEv2 VPN Configuration
I have a IKEv2 VPN Setup and downloaded the Windows configuration script. Works fine.
I downloaded the IOS MacOS configuration script, but I am unsure of how to install on iphone. Only file in downloaded IPSec_IKEv2 folder is XXXXX.mobileconfig format. Not sure what to do with it.
To install the mobileconfig file, you may download it on your iPhone, and then Save to files.
Then go to VPN & Device Management, you will a download profile, please click on it and install it.
- 212 Nebula Ideas
- 548 USG FLEX H Series
- 341 Security Ideas
- 295 Service & License
- 468 News and Release
