Usg100 2 internet connections Nat and policies
MarcoMaroso
I have 2 internet connections each with its own modem/router.
Both of these are connected to my firewall and I need to access services behind my firewall from both of them.
Actually I can access my services behind the firewall only from one of the 2 connections but I need this working also from the second.
I was monitoring the policies behavior lookklo at the logs and filtering connections by ip...and I see that requests from connection1 and those from connection2 match the rules and get Forwared ...but those from connection2 won't work...they are granted access matching the rules but for some strange reason they don't get me to the service.
This is so weerd!
Any suggestions?
Thanks in advance.
This is so weerd!
Any suggestions?
Thanks in advance.
Hi @MarcoMaroso,
To access services from both internet connections, create two NAT rules as follows.
In this example, wan1 and wan2_ppp are configured on USG 100.
After NAT rules are created, go to Firewall to add a rule for accessing the server and service in LAN1.
If you use customized trunk instead of the default wan trunk, make sure the wan interfaces for NAT rules are added to this trunk.
For example, wan1 and wan2_ppp are used for NAT rules, you need to add the interface wan1 and wan2_ppp to this customized trunk.
If you add wan2 instead of wan2_ppp, it is not working.
- 435 Beta Program
- 176 Nebula Ideas
- 119 Nebula Status and Incidents
- 430 USG FLEX H Series
- 299 Security Ideas
- 79 Switch Ideas
- 276 Service & License
- 427 News and Release
- 89 Security Highlight
