usg20w-vpn drops internet on wan interface every 45 minutes
udoc
udoc Posts: 3 image  Freshman Member
HI,
running usg20w-vpn with latest firmware. this setup was working for years behind a surfboard8200 modem and comcast internet. we upgraded service to 500mb and now internet signal drops after 45 minutes and does not return w/o reboot. comcast says it is firewall. how can i get more details from firewall device?
when internet drops, i can connect to usg web interface from internal devices still when at office.
any thoughts on what may be occurring or direction to research?
thanks.
  • udoc
    …I also tried with comcast business modem in router mode and cascade to usg but usg still drops.
    tried comcast device in bridge mode and drops. tried a different netgear brand router also and still dropped at 45 minutes.
    PeterUK Posts: 4,546 image  Guru Member
    Do pings drop? Run
    ping -t 1.1.1.1
    Do a packet capture on USG for the WAN note make captured packet files size big then when it drops on a idle connection with ping look at ARP the DHCP
    another thing you can do is put a switch between modem and USG to see if thats stable.
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,393 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    Hi @udoc
    We suggest you check the monitor log(Monitor > Log) to see if there are any suspicious logs during the internet drop. Besides, when the internet drops which device do you reboot it? Is the usg20w-vpn or SURFboard 8200 modem?
    Here's an unusual situation: even if you use a different brand of router, the internet still drops every 45 minutes. This could be related to the ISP environment or the modem. Thanks.
