NTP Service (Server) on USG for SOHO Devices
ChrisGer
ChrisGer Posts: 206 image  Ally Member
Zyxel Certified Network Administrator - Switch Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Nebula
edited July 2024 in Security Ideas
It would be great, if the USG can also serve a NTP Sever functionality and the USG is the Device to sync the local time with NTP-Server in the extranet for small/remote offices.
Benefit: no additional time server is required and the USG can serve correct date/time to domain ad client systems  during a broken extranet connectivity
5 votes
In Plan · Last Updated
Not in USG/ATP/FLEX series. Has plan to support in new hardware.
  • PiRX2000
    PiRX2000 Posts: 7 image  Freshman Member
    And I am also waiting for such feature! It would be great if USG can be the time source in the LAN.
  • Tattoofreak
    Tattoofreak Posts: 10 image  Freshman Member
    +1
    A very beautiful implementation like pfSense would be very nice! Listening on every chosen interface so that the according VLAN's default gateway can be used as NTP server.
  • imaohw
    imaohw Posts: 124 image  Ally Member
    First Comment First Answer Friend Collector Seventh Anniversary
    +1 This would be very helpful.
  • RalfQ
    RalfQ Posts: 2 image  Freshman Member
    +1 Please add this feature.
  • Wojtek
    Wojtek Posts: 18 image  Freshman Member
    First Answer First Comment Sixth Anniversary
    Quote:
    "In Plan ·Last Updated September 2022
    Not in USG/ATP/FLEX series. Has plan to support in new hardware."
    And what about the new hardware?
  • Wojtek
    Are the new FLEXxxxH series devices NTP servers?
  • Zyxel_Joshua
    Zyxel_Joshua Posts: 62 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security 5 Answers First Comment Friend Collector
    edited November 2023
    Hi @Wojtek ,
    The FELX H series support enable NTP server via CLI.
      > edit running
      running config# / vrf main ntp server-subnet 1 allow {<A.B.C.D/M> | all}
      running config# commit
      running config# copy running startup
      running config# exit
    But there an minor issue in current version. The CLI settings for NTP server will be clean if apply system settings on GUI. Will fix in Q1, 2024 release.
  • Wojtek
    Good news, thank you very much. :)
    Will NTP be available via GUI in the future?
  • Zyxel_Joshua
    Sorry, no plan at the moment of the GUI design.
    Plans are likely Q3 2024.
  • Wojtek
    Thank you for the information.
