How to configure SSID Private and public WAC500
Damien_SBM
Damien_SBM Posts: 7  Freshman Member
edited May 2024 in Wireless
I would like to know if it's possible with the WAC 500 in standalone mode to make 2 SSID.
Exemple :
Private for all users in the company 192.168.x.x
Public for the external users 172.16.x.x
The step to create the two SSID is quite easy but the two SSID get the same DHCP…
I try to change the ID VLAN on the Public SSID but i don't know where to manage other VLAN in WAC 500 ( or if it's possible? )
Thanks for you answer,
Damien
Best Answers
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317  Zyxel Employee
    Hi @Damien_SBM ,
    It's possible to achieve this setup by configuring relevant VLANs on your network gateway and any relevant switches, not WAC500.
    Zyxel_Judy
  • Zyxel_Judy
    Hi @Damien_SBM ,
    You're right.
    You can configure VLANs at USG FLEX web GUI > Configuration > Network > Interface > VLAN > Click Add button.
    Zyxel_Judy
  • Zyxel_Judy
    Hi @Damien_SBM ,
    Zyxel_Judy
  • Damien_SBM
    Thanks @Zyxel_Judy
    So i have to manage on my USG FLEX 500 2 VLAN ?
    If you have any advice… :)
  • Zyxel_Judy
    Hi @Damien_SBM ,
    You're right.
    Zyxel_Judy
