How to configure SSID Private and public WAC500
I would like to know if it's possible with the WAC 500 in standalone mode to make 2 SSID.
Exemple :
Private for all users in the company 192.168.x.x
Public for the external users 172.16.x.x
The step to create the two SSID is quite easy but the two SSID get the same DHCP…
I try to change the ID VLAN on the Public SSID but i don't know where to manage other VLAN in WAC 500 ( or if it's possible? )
Thanks for you answer,
Damien
Best Answers
Hi @Damien_SBM ,
It's possible to achieve this setup by configuring relevant VLANs on your network gateway and any relevant switches, not WAC500.
Zyxel_Judy
Hi @Damien_SBM ,
You're right.
You can configure VLANs at USG FLEX web GUI > Configuration > Network > Interface > VLAN > Click Add button.
Zyxel_Judy
Hi @Damien_SBM ,
Zyxel_Judy
Thanks @Zyxel_Judy
So i have to manage on my USG FLEX 500 2 VLAN ?
If you have any advice… :)0 -
Hi @Damien_SBM ,
You're right.
Zyxel_Judy
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 455 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 279 Service & License
- 436 News and Release
- 91 Security Highlight
