Can my GS1008HP hold all these devices?
Hello i have a GS1008HP switch.
Connected to him there were x3 ip cam 48v 13w max poe.
Now i want to connect to him x3 access point with 12v 13w max poe (i use x3 poe splitter from 48v to 12v for these).
Can the switch give all this power? or may it can't and goes to damage itselfe?
Hello @TipoTimido
Thank you for reaching out.
The Zyxel GS1008HP switch provides a total PoE power budget of 60W, with a maximum of 30W per port.
If each of your 6 devices (3 IP cameras and 3 access points) consumes the maximum 13W, this would total 78W (6 x 13W), which exceeds the switch's 60W PoE budget. In such cases, the switch might power off the powered devices. Therefore, it isn’t recommended to connect all 6 devices to a single GS1008HP.
Nami
i read that the GS1008HP can erogate 30W per eth port.
So i think that it can handle all those devices…
Hello @TipoTimido
Nami
You right, thanks for explaination.
- 213 Nebula Ideas
- 564 USG FLEX H Series
- 342 Security Ideas
- 295 Service & License
- 471 News and Release
