Is LAG possible between XGS1210-12 and XGS1010-12 switches ?
BDR
BDR Posts: 1 image  Freshman Member
I wonder if it is possible to connect a managed XGS1210-12 switch to an unmanaged XGS1010-12 switch via a link aggregated group (LAG)?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,615 image  Zyxel Employee
    Hi @BDR,
    Since XGS1010-12 is an unmanaged switch, you cannot set up LAG on it. So, it is not possible to connect XGS1210-12 with XGS1010-12 via LAG.
    Zyxel Melen
  • Zyxel_Melen
    Hi @BDR,
    Zyxel Melen
