FLEX 700H Virtual interface on external interface
DanniKool
DanniKool Posts: 62
First Answer First Comment Friend Collector Eighth Anniversary
image  Ally Member
Hi
Is it not yet possible to create a virtual interface on an external WAN interface (ge1)?
    PeterUK Posts: 4,841
    image  Guru Member
    edited November 2023 Answer ✓
    just without :1
    you first need to be in editing then
    vrf main interface ethernet ge1 ipv4 address 192.168.254.1/29
    then
    commit
    in a setup I did with it showed as working but could be some problems
    image  Guru Member
    you can by SSH like
    edit running
    vrf main interface ethernet ge2 ipv4 address 192.168.254.1/29
    commit
    copy running startup
    But when you change stuff in the UI it may not stick and has to be applied again and may be problems
  • DanniKool
    DanniKool Posts: 62
    image  Ally Member
    I would like to create a secondary interface to my primary static WAN IP on ge1 as a virtual interface. This option is possible on the older Zyxel firewalls.
    So the command should maybe be something like this:
    vrf main interface ethernet ge1:1 ipv4 address 192.168.254.1/29
    The above gives me an error using ssh. So i guess it's not possible at the moment?
    Anyway, i think i can overcome this by using one of my available WAN IP's as IP instead of interface in one of my VPN's……
    image  Guru Member
    just without :1
    then
    commit
  • DanniKool
    DanniKool Posts: 62
    image  Ally Member
    Thanks Peter, it's seems to be working!
