What firewall rules are needed to allow L2TP over IPSEC from Windows 11
So I'm guessing you have two routers? one is 192.168.1.1 your first router and 192.168.0.1 is the LAN of the Zyxel with WAN2 to your first router? and your PC VPN to Zyxel?
the Zyxel has a 192.168.1.1 subnet that you need to change
Hi
No, the remote PC (i.e. the one at home trying to connect via VPN) has a router 192.168.1.1
The zyxel has public IPs from 2 different providers.
In your VPN connection rule what is the Related Settings zone list as? Ipsec_VPN
is the LAN routeing rule top of the list?
If you mean the Members, that was created by the Wizard. I've only used the Wizard to create the VPN settings.
And yes, it's the first of 2 routes
Just a reminder that if I turn off the firewall, everything works, so to me the issue is a firewall rule needs to be created to "allow" the traffic.
If you do ping -t 192.168.0.11 from the remote PC do you see logs of this?
…but you have a rule Ipsec_VPN to LAN1 which should do that…
Hi
Thanks for your help so far, but now we're getting outside of my knowledge of the Zyxel, I'm going to have to read up on logging and how it works first to answer your question, because it looks like logging is disabled by default. I'll take a look tomorrow when I'm at work and report back.
Thats only if you want to Email logging
The bit to look at is in monitor > log use the show filter put in destination address 192.168.0.11 should show up if blocked
You've taught me something (else) new.
Yes it's being blocked by the default rule.
Out of interest, I tried creating an explicit rule from 192.168.50.1 to LAN1 and vice versa, the ping now no longer appears in the logs, but still doesn't get through.
- 431 Beta Program
- 2.6K Nebula
- 166 Nebula Ideas
- 6K Security
- 366 USG FLEX H Series
- 293 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 264 Service & License
- 408 News and Release
- 87 Security Advisories
- 3.9K FAQ
- 83 Security Highlight
