[Campaign] Zyxel Network Detective - Case #2 is OPEN! (Answer Revealed)
Detecting a WiFi Network Error
Hi, all tech enthusiasts!
After the tremendous success of our Case #1: Crack the for Switch challenge, we are happy to announce our next epic adventure, Case #2: Crack the Case for WiFi Network. If you enjoyed uncovering network errors in our previous challenge, get ready for a new and exciting journey into the world of WiFi connectivity.
Join us now and you'll not only have the chance to win fantastic prizes but also earn a special community badge and unique achievements that will truly set you apart.
You're not alone in this! Join the discussion with fellow enthusiasts tracking network errors. Share insights and seek help HERE.
Ready to solve the case, Zyxel detective!
Hello detectives!
Did you know AP’s behavior when enable Load Balancing?
APs with Load Balancing enabled send out broadcast packets every ten seconds to announce their loading status and detect if there are other APs with Load Balancing enabled in the environment.
For Example, when we deploy two APs in the same room with Load Balancing enabled, while one of them (AP-1) is overloaded. Through the broadcast packet, it will know that the other AP (AP-2) is under loaded.
Once an overloaded AP detects an under-loaded AP in the environment, it will disconnect wireless devices that exceed the threshold one by one, until its client number equals to the threshold.
Keep up the investigation,
Watson 🕵️
When you have eliminated the impossible, whatever remains, however improbable, must be the truth.
Are you merely pursuing elusive phantoms or have you pieced the puzzle together for this case?
Check out the revealed answer here.
See you in the final Case #3: Crack the Case for Firewall, Zyxel Detective!
Watson🕵️
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
