What firewall rules are needed to allow L2TP over IPSEC from Windows 11
and the VPN is by WAN2?
Its possible the Photocopier your pinging only allows from the subnet its in so test to a PC
but if the ping makes it and a reply happens then it should do back to the VPN tunnel.
if you have "Use Policy Route to control dynamic IPSec rules" checked uncheck it
Earlier you said to disable SNAT on the policy which I did. With the firewall still down, I re-enabled it, and now I have full traffic across the VPN, directory browsing, and pinging the photocopier. It looks like SNAT is needed for the VPN?
The SNAT will make your traffic come from 192.168.0.254 from the VPN instead of the VPN IP range so if your happy with that.
It is odd that you can't ping with SNAT none as the device will see its from 192.168.50.1 use gateway 192.168.0.254 to send it back.
- 439 Beta Program
- 190 Nebula Ideas
- 6.2K Security
- 466 USG FLEX H Series
- 305 Security Ideas
- 81 Switch Ideas
- 281 Service & License
- 440 News and Release
- 4.3K FAQ
- 93 Security Highlight
