FLEX 700H Virtual interface on external interface
Hi
Is it not yet possible to create a virtual interface on an external WAN interface (ge1)?
just without :1
you first need to be in editing then
vrf main interface ethernet ge1 ipv4 address 192.168.254.1/29
then
commit
in a setup I did with it showed as working but could be some problems
you can by SSH like
edit running
vrf main interface ethernet ge2 ipv4 address 192.168.254.1/29
commit
copy running startupBut when you change stuff in the UI it may not stick and has to be applied again and may be problems
I would like to create a secondary interface to my primary static WAN IP on ge1 as a virtual interface. This option is possible on the older Zyxel firewalls.
So the command should maybe be something like this:
vrf main interface ethernet ge1:1 ipv4 address 192.168.254.1/29
The above gives me an error using ssh. So i guess it's not possible at the moment?Anyway, i think i can overcome this by using one of my available WAN IP's as IP instead of interface in one of my VPN's……
just without :1
then
commit
Thanks Peter, it's seems to be working!
- 237 Nebula Ideas
- 6.8K Security
- 743 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
