why web portal\web authentication page is not appearing on screen of users laptop\mobile?
hi ,
we have using Zyxel UAG5100 device, i am facing an issue every after 4 days web portal\web authentication page is not appearing on screen of user machine\device, then i need to restart device every time to work
kindly help me to solve this issue
It seems the httpd daemon being dead after running for 4 days.
Normally, I would suggest the operation below to avoid this issue happening.- Limit HTTP connection session per IP
- Bypass some common domain in web auth
- Disable "force user authentication"
However, it only slows down the issue happening, not actually fix it.
I would suggest upgrading to a newer model( such as USGFLEX series) since UAG5100 has already end of support since 2020-12-311
What kind of services or features are running on this device?
What is the average workload or CPU load?
Is it running any form of VPN with IPSEC logging?
Does it run any other services not affected by this issue?
this device used for wifi connecting to inhouse guest sometimes that web page doesnt appear then i need to restart the services or machine uag5100
no other services are running on it
cpu usage 92%
no vpn or ipsec are using
whenever user try to login back to access internet the web portal is not appearing on screen instead of displaying no internet ,is this systems logs issue are some configuration issue?
after restarting the Zyxel UAG5100 gateway machine, then only web page appearing on screen
kindly let me know
OK, thank you for the extra details. Looking forward to suggestions from someone knowing this device better than me.
Have you checked if it is possible to update the firmware on your device?
tried updating firmware ,but still same
may be its system log issue?
Does it happen to all accounts or specific accounts?
What's the reauthentication time setting for the accounts?0 -
for all exiting accounts and when try to use new device for connection the webportal not appearing instead it displaying no internet
when existing accounts when they trying to renew or connect back the web portal not appearing
i need to restart the whole gateway Zyxel UAG5100
after restarting it started to appear webportal
I would suggest upgrading to a newer model( such as USGFLEX series) since UAG5100 has already end of support since 2020-12-311 -
Aha. Now I understand the problem. HTTP requests flooding the device over time, making it unable to operate for more than a few days, because too many HTTP packets from the combined amount of devices being used. Good suggestion to upgrade to a supported device.
- 441 Beta Program
- 210 Nebula Ideas
- 538 USG FLEX H Series
- 340 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 464 News and Release
