SSLVPN port blocking since USGFLEX100 firmware update ver V5.37(ABUH.1)
We are experiencing problems since the firmware update of a USGFLEX100 unit with firmware V5.37(ABUH.1) and SSLVPN connection.
WAN connection with authorized access port to the SSLVPN connection from only Spanish IP's. Before upgrading to the new firmware version everything worked fine. Since upgrading to the new firmware version, this has stopped working.
If we disable the restriction by IP Geophraphic IP, the connections will work again but from anywhere in the world and this would not be a good performance of the firewall security.
Best Regards,
Juan Antonio
Hi @Infosetel2020,
Thanks for reporting this issue to us. We will run the test and update the test result with you.
Hi Emily
Today I tried it again and it already works.
Thank you!
Juan Antonio
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 124 Nebula Status and Incidents
- 6.3K Security
- 488 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 455 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
