Advanced DHCP options is missing
networx
networx Posts: 9 image  Freshman Member
I'm not able to add advanced DHCP options to my scope. Option seems to be missing.
firmware V1.10(ABZH.0)
USG FLEX 500H
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,350 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    Hi @networx
    Thank you for sharing your valuable feedback with us. We will support the DHCP extended options in the future firmware😊. As the screenshot below shows on the ATP/USG Flex models.
  • Zyxel_Jeff
    Hi @networx
    Could you provide the remote Web-GUI to us for further checking? We will send a private message to you later, please check your e-mail in-box. Thanks.
    PeterUK Posts: 4,264 image  Guru Member
    Yes them options for LAN DHCP server are missing not sure if you can add them by SSH
    One workaround is to use a low end old USG as DHCP server and point gateway to FLEX 500H
  • Zyxel_Jeff
    Hi @networx
  • kruess
    kruess Posts: 20 image  Freshman Member
    First Comment First Answer Friend Collector Fourth Anniversary
    Wow, what a bad start for the new GUI… how can Zyxel go forward with such a minimal and cumbersome management GUI… :-(((
