ZW USG 1100 100% flash usage
Hi.
ZW USG 1100 fw v4.31(aapk.1_its-wk43-r86075 show 100% flash usage.
We have no files on it. Only 3 conf files.
Diagnostics, packet capture, wireless frame capture are empty, all dirs via cli (dir, packet_trace, script, idp) shows empty.
How i can clean flash?
Hi @alexey,We need the remote access to check on what kind of files occupied your USG1100 flash space.I will send you the required information in the private message.0
Hi @Fernando12,
You can use the command to delete unnecessary file when flash is full.
debug system _disk-cleanup
I get this error when executing the command.
Hi @Fernando12,
The command "debug system _disk-cleanup" is available since firmware 4.35.
Make sure your ZyWALL 1100 is upgraded to firmware 4.35 or later versions.
If the command is still not found in the latest firmware version, give me the remote access of SSH or console in private message.
- 434 Beta Program
- 2.6K Nebula
- 171 Nebula Ideas
- 403 USG FLEX H Series
- 296 Security Ideas
- 1.5K Switch
- 43 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 4K FAQ
- 83 Security Highlight
