DMZ Setup with Single Static IP but No 1:1 NAT
I have checked the internet/forum but couldn't reach a solution.
I have been provided only one static IP by our ISP. And I want to setup a server and give it the public IP (direct DMZ access) so that there is no NAT (not even 1:1) on that specific one server. Other machines on lan2 behind zyxell should also have internet access. Can you guide on how to do it? Port Forwarding and NAT is causing issue with the WebRTC Protocol and as a result, I want to directly put the server on public ip.
Please note, I can not have any NAT on DMZ as it is causing issues with the WebRTC protocol.
I have ZyWALL USG 20.0
You'll ahve to have at least (2) public IPs. Either you obtain a 2nd static for the WEB RTC server or else you assign the one static you already have to the WEB RTC and let the USG20 grab a DHCP address on it's WAN interface.0
You can read more detail on this subject from my post here https://businessforum.zyxel.com/discussion/1324/how-to-route-multiple-public-static-ips-with-zyxel#latest
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
