Google Authenticator App Usage With SSL VPN On Flex 100H Question
We have just purchased a Flex 100H and about to setup SSL VPN
Am I correct in thinking that if you setup a SSL VPN User to use Google Authenticator as the 2FA option you have to manually go to the Zyxels 2FA site after connection to input the code ?
We plan on using the Secuextender Client
If so is there a way to automate this to make it more user friendly for the remote workers ?
Or is there a better VPN option in the Flex i.e. LT2P, Ipsec that would make it easier ti implement Google Authenticator.
Many thanks for your time.
Hi @JCE,
2FA Google Authenticator for VPN access will be supported in the next firmware 1.20.
When you use VPN Client (VPN Client IPSec_SSL_VPN_7.7.40.019) to open IKEv2/SSL VPN tunnel, the 2FA authentication page for will pop up automatically when the tunnel is opened.0
Hi @JCE,
When you use VPN Client (VPN Client IPSec_SSL_VPN_7.7.40.019) to open IKEv2/SSL VPN tunnel, the 2FA authentication page for will pop up automatically when the tunnel is opened.0 -
Hi Emily,
Many thanks for your reply.
Do we have an idea when Firmware 1.2 will be released as we bought this 100H to replace a USG 40 for which we were running SSL VPN with 2FA via Email Link and now we cant have any form of 2FA for VPN on the new device which seems a step backward in security for us.
Also can you still use the Secu Extender SSL VPN Client V4 to connect to the 100H vis SSL VPN or do you now have to purchase the more advanced client or use Open VPN client ?
Thank you for your time.
Hi @JCE,
The next official firmware 1.20 will be released in Apr. 2024.
You need to use IPSec_SSL_VPN_7.7.40.019(Windows) to establish SSL VPN to USG FLEX H device.
- 429 Beta Program
- 2.6K Nebula
- 163 Nebula Ideas
- 6K Security
- 350 USG FLEX H Series
- 291 Security Ideas
- 1.5K Switch
- 42 Wireless Ideas
- 6.6K Consumer Product
- 261 Service & License
- 406 News and Release
- 87 Security Advisories
- 3.8K FAQ
- 82 Security Highlight
