Case #3: Crack the Case for Firewall (Answer Revealed)
Zyxel_Richard
Zyxel_Richard Posts: 255 image  Master Member
Zyxel Certified Network Engineer Level 2 - WLAN Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 2 - Security
Solve a Firewall Enigma
Greetings, fellow tech enthusiasts! Following the resounding success of our Case #2: Crack the Case for WiFi Network challenge, we are thrilled to introduce our final quest, Case #3: Crack the Case for Firewall . If you relished resolving network errors in our previous challenges, prepare for an exhilarating journey deep into the security firewalls and win fantastic prizes now.
The Ultimate Mission
In Case #3: Crack the Case for Firewall , your mission is delving deeper, examining the full circumstances to unveil potential network errors within security firewalls. Your acute technical expertise will be indispensable to identify the issues and orchestrating the resolution to ensure your network safeguarded by strong and reliable security firewalls.
Cooperative Effort in Motion
You’re not on your own in this mission! Become part of conversations alongside other tech enthusiasts, share your observations, and exchange your findings here!
In Pursuit of Glory, Zyxel Detective!
  • Zyxel-Watson
    Zyxel-Watson Posts: 16 image  Zyxel Employee
    Network Detective Badge First Comment Friend Collector
    Hello detectives!
    Do you know how to configure site-to-site VPN in Nebula between two devices under one organization?
    Steps:
    1. Select WAN interface to establish the VPN tunnel
    2. Select LAN Subnet that can be accessed through the VPN tunnel
    3. Select “Site-to-Site” in Nebula VPN topology
    4. Repeat step1 to step3 on the other firewall
    What’s even better, settings in step 1-3 can be configured in a single page!
    Once the VPN connection is established, you can monitor the VPN connection state under each site.
    Keep up the investigation,
    Watson🕵️
    When you have eliminated the impossible, whatever remains, however improbable, must be the truth.
  • Zyxel-Watson
    I'm certain you've pieced all the puzzles together, Zyxel Detective!
    Check out the revealed answer here!
    We'll be reuniting with you very soon and thank you for joining the hunt!
    Watson🕵️
