GS1100/16 does not auto-negotiate with 2.5Gbit ethernet adapter
agokhandemir
agokhandemir Posts: 6
edited December 2023 in Switch
Hello everyone,
I have a GS1100/16 and I've been using it in my home network with 100Mbit and 1Gbit devices without any problems. I recently bought a mini pc with two 2.5Gbit ethernet ports and they won't negotiate with the switch unless I select 10Mbit full duplex mode, which is terribly slow :)
I have taken the following steps to figure out the problem:
  • Tried Different CAT6/CAT5e cables,
  • Tried both 2.5Gbit ports on the PC,
  • Tried different ports on the switch,
None of them worked.
I also tested the 2.5Gbit Ethernet ports on the PC with the LAN ports on my modem (1Gbit), they work and auto-negotiate at 1Gbit.
I know this switch is probably 10 years old tech-wise, but I want to know if there were any limitations for connections above 1Gbit with this switch. I do not think the switch is defective because it works fine with 1Gbit devices.
I look forward to hearing what you think.
Thank you
  • Zyxel_Nami
    Zyxel_Nami Posts: 659  Zyxel Employee
    Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate
    Hi @agokhandemir
    Our local testing, involving a Windows 11 system with an I226-V (on-board driver) connected to the ES1100-16 switch, showed negotiation at 100M. Given this result, along with your experience, it appears there may be a compatibility issue between the ES1100-16 (a 100M switch) and certain 2.5G devices.
    To ensure optimal performance and to fully utilize 2.5G speeds in your network, we recommend considering a dedicated 2.5G switch such as the MG100 series.
    Nami
«1
    PeterUK Posts: 3,892  Guru Member
    What make/model is the motherboard?
    a driver update can fix this
  • The motherboard is not a known brand, but the ethernet adapters are Intel I226-V. I have the latest Intel Ethernet Driver Pack installed. They work with other network devices in my home network, it is just this switch.🙄
  • Zyxel_Nami
    Hello @agokhandemir
    To assist you effectively with the GS1100-16 auto-negotiation issue, we'll need the switch's serial number. Please provide this information via the private message I sent.
    Thank you
    Nami
  • Peter, thanks for the answer, but I already had this driver. However, I removed the existing driver and installed your driver, but nothing changed.
  • Zyxel_Nami
    Hello @agokhandemir
    I have just received your information. However, the picture you provided showed the model name is ES1100-16, not GS1100-16. Could you please confirm the model name of your switch?
    Nami
  • Yes, It is ES1100-16 (without PoE ports). Sorry for the inconvenience.
  • Zyxel_Nami
    Hi @agokhandemir
    To help resolve the auto-negotiation issue with your ES1100-16 switch, could you please check if the Energy Efficient Ethernet (EEE) is activated on your PC?
    If it is enabled, please try disabling EEE and unplugging the ethernet cable, then re-plugging it to test the connection again.
    Let us know how it goes!
    Nami
  • Hello @Zyxel_Nami
    I checked the advanced controller properties in Windows and EEE is already disabled.
    When a cable is plugged in, the lights would flicker even before Windows boots, but that does not happen with my switch. I was curious because 2.5Gbit ports work just fine with a regular modem.
    Anyway, I won't bother you anymore. Since it is an unmanaged switch, there is not much you can do.
  • Zyxel_Nami
    Hi @agokhandemir
    Nami
