USG40w WLAN issues
Lately i have been having an issue with our WiFi
If i restart the router our wifi works perfectly fine but then the next day i have the same issue were while i try to connect i get an error "cannot connect to this network"
Bellow you can see the logs:
471 | 2018-12-19 14:16:10 | notice | Wireless LAN | Station has blocked. reason 1, event by Hostapd3. Interface:wlan-1-1: Station: 6C:94:F8:39:03:79 [count=2] | IEEE 802.11 | ||
472 | 2018-12-19 14:16:10 | notice | Wireless LAN | Station has blocked. reason 2, event by prev-Auth Failed. Interface:wlan-1-1: Station: 6C:94:F8:39:03:79 [count=2] | IEEE 802.11 | ||
473 | 2018-12-19 14:16:10 | notice | Wireless LAN | Station has deauth. reason 1, flags=0x3 Interface:wlan-1-1: Station: 6C:94:F8:39:03:79 [count=2] | IEEE 802.11 | ||
474 | 2018-12-19 14:16:10 | notice | Wireless LAN | WPA authenticator requests disconnect: reason 1. Interface:wlan-1-1: Station: 6C:94:F8:39:03:79 [count=2] | WPA | ||
475 | 2018-12-19 14:16:10 | notice | Wireless LAN | Station has deauth. reason 2, flags=0x3 Interface:wlan-1-1: Station: 6C:94:F8:39:03:79 [count=2] | IEEE 802.11 | ||
476 | 2018-12-19 14:16:10 | notice | Wireless LAN | WPA authenticator requests disconnect: reason 2. Interface:wlan-1-1: Station: 6C:94:F8:39:03:79 [count=2] | WPA | ||
478 | 2018-12-19 14:16:06 | notice | Wireless LAN | Station has associated. Interface:wlan-1-1: Station: 6C:94:F8:39:03:79 [count=2] | IEEE 802.11 | ||
484 | 2018-12-19 14:15:59 | notice | Wireless LAN | Station has blocked. reason 1, event by Hostapd3. Interface:wlan-1-1: Station: 6C:94:F8:39:03:79 | IEEE 802.11 | ||
485 | 2018-12-19 14:15:59 | notice | Wireless LAN | Station has blocked. reason 2, event by prev-Auth Failed. Interface:wlan-1-1: Station: 6C:94:F8:39:03:79 | IEEE 802.11 | ||
486 | 2018-12-19 14:15:59 | notice | Wireless LAN | Station has deauth. reason 1, flags=0x3 Interface:wlan-1-1: Station: 6C:94:F8:39:03:79 | IEEE 802.11 | ||
487 | 2018-12-19 14:15:59 | notice | Wireless LAN | WPA authenticator requests disconnect: reason 1. Interface:wlan-1-1: Station: 6C:94:F8:39:03:79 | WPA | ||
488 | 2018-12-19 14:15:59 | notice | Wireless LAN | Station has deauth. reason 2, flags=0x3 Interface:wlan-1-1: Station: 6C:94:F8:39:03:79 | IEEE 802.11 | ||
489 | 2018-12-19 14:15:59 | notice | Wireless LAN | WPA authenticator requests disconnect: reason 2. Interface:wlan-1-1: Station: 6C:94:F8:39:03:79 | WPA | ||
494 | 2018-12-19 14:15:55 | notice | Wireless LAN | Station has associated. Interface:wlan-1-1: Station: 6C:94:F8:39:03:79 | IEEE 802.11 |
Hi @Fotakisgr
Which model is working in your environment?
As I know in other threads have the same symptom in local WiFi interface.
You may reference to Here0
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
