editing post not working
PeterUK
PeterUK Posts: 4,119 image  Guru Member
edited March 2024 in Community Feedback
  • Zyxel_Melen
    Zyxel_Melen Posts: 3,928 image  Guru Member
    Hi @PeterUK,
    Thanks for your notice. We found that the edit function is available for editing a post but not a comment. We are checking on it now. I will keep you posted once this problem is fixed.
    Zyxel Melen
  • Zyxel_Melen
    edited December 2023
    Hi @PeterUK,
    The problem is fixed. You may edit the comment now.
    Zyxel Melen
Leave a Comment
Rich Text Editor. To edit a paragraph's style, hit tab to get to the paragraph menu. From there you will be able to pick one style. Nothing defaults to paragraph. An inline formatting menu will show up when you select text. Hit tab to get into that menu. Some elements, such as rich link embeds, images, loading indicators, and error messages may get inserted into the editor. You may navigate to these using the arrow keys inside of the editor and delete them with the delete or backspace key.
