uOS Bugs ? flex500h default interface rename / domain definition
Migrating from flex500 to flex500h. I only monitor in Nebula as i simply prefer on premise only.
- I cannot rename ge 3 or ge 4 interface name as mostly anywhere in uOSthe Name fields are not editable. (ried firefox and chrome browser)
2. in the DNS i cannot enter another domain than myrouter.local (btw i also miss the domain in the general router settings
Is this a bug ?
To rename a interface you must remove all reference settings to it plus set zone to none to do this setup and a not in use port with IP with its rule zone to Zywall and connect to that port and IP to start removing reference settings from GE3 and GE4 then you can remove them and add it back as a new name.
To add another Record click the + enter domain/IP and click tick and apply
Peter,
Perfect !! THANKS A LOT.
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
