VPN stopped working
PeterUK
PeterUK Posts: 4,446 image  Guru Member
VPN300 V5.37(ABFC.0)
So today I found out my VPN link was down so on my Flex200 I tried disable and enable the rule no help over to VPN300 I disable and enable now its up and running again not sure if it will happen again.
«1
  • Zyxel_Cooldia
    Hi @PeterUK,
    During the time the problem occurred, are there any logs for the 'IKE' category?
    Did not think to take logs when it happened which I should of done but even now there is a odd log where I have on my Zywall 110 doing a Remote Access test to VPN300 but the rule is disabled on VPN300 side only site to site link_to_flex200_4G is on for Ge4 saying:
    [ID] : Tunnel [link_to_flex200_4G] Local IP mismatch
    which the site to site for link_to_flex200_4G is currently fine and is caused by Zywall 110 trying to connect on Ge3.
    Not sure yet but could a IP change of Ge4 cause the link to fail and not register the new IP? The 4G is by Nighthawk M2 Mobile Router in IP passthrough the 10. IP does not change that much but maybe thats the reason?
    nope not that
    Its happened again
    uptime 20days with firmware
    V5.37(xxxx.1)
    also done diaginfo if needed
    Flex 200
    3
    2023-12-14 17:01:56
    info
    IKE
    Phase 1 IKE SA process done
    94.173.27.164:4500
    31.94.60.226:4500
    IKE_LOG
    4
    2023-12-14 17:01:56
    info
    IKE
    Send:[ID][HASH]
    94.173.27.164:4500
    31.94.60.226:4500
    IKE_LOG
    5
    2023-12-14 17:01:56
    info
    IKE
    The cookie pair is : 0x9c9d06ae7a475c2f / 0x64748c64aa6aea90 [count=2]
    94.173.27.164:4500
    31.94.60.226:4500
    IKE_LOG
    6
    2023-12-14 17:01:56
    info
    IKE
    Recv:[ID][HASH]
    31.94.60.226:4500
    94.173.27.164:4500
    IKE_LOG
    7
    2023-12-14 17:01:56
    info
    IKE
    The cookie pair is : 0x64748c64aa6aea90 / 0x9c9d06ae7a475c2f
    31.94.60.226:4500
    94.173.27.164:4500
    IKE_LOG
    8
    2023-12-14 17:01:56
    info
    IKE
    Send:[KE][NONCE][PRV][PRV]
    94.173.27.164:500
    31.94.60.226:61072
    IKE_LOG
    9
    2023-12-14 17:01:56
    info
    IKE
    Recv:[KE][NONCE][PRV][PRV]
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    10
    2023-12-14 17:01:55
    info
    IKE
    Send:[SA][VID][VID][VID][VID][VID][VID][VID][VID][VID][VID]
    94.173.27.164:500
    31.94.60.226:61072
    IKE_LOG
    11
    2023-12-14 17:01:55
    info
    IKE
    94.173.27.164:500
    31.94.60.226:61072
    IKE_LOG
    12
    2023-12-14 17:01:55
    info
    IKE
    Recv IKE sa: SA([0] protocol = IKE (1), AES CBC key len = 128, HMAC-SHA1 PRF, HMAC-SHA1-96, 1024 bit MODP; ).
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    13
    2023-12-14 17:01:55
    info
    IKE
    Recv:[SA][VID][VID][VID][VID][VID][VID][VID][VID][VID][VID]
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    14
    2023-12-14 17:01:55
    info
    IKE
    The cookie pair is : 0x64748c64aa6aea90 / 0x9c9d06ae7a475c2f [count=2]
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    15
    2023-12-14 17:01:55
    info
    IKE
    Recv Main Mode request from [31.94.60.226]
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    16
    2023-12-14 17:01:55
    info
    IKE
    The cookie pair is : 0x9c9d06ae7a475c2f / 0x0000000000000000
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    31
    2023-12-14 17:01:49
    info
    IKE
    Recv:[HASH][NOTIFY:R_U_THERE_ACK]
    192.168.255.241:500
    192.168.255.237:500
    IKE_LOG
    32
    2023-12-14 17:01:49
    info
    IKE
    Send:[HASH][NOTIFY:R_U_THERE]
    192.168.255.237:500
    192.168.255.241:500
    IKE_LOG
    55
    2023-12-14 17:01:40
    info
    IKE
    Send:[HASH][NOTIFY:R_U_THERE_ACK]
    192.168.255.237:500
    192.168.255.241:500
    IKE_LOG
    56
    2023-12-14 17:01:40
    info
    IKE
    The cookie pair is : 0xf6c98f4ae079b9ef / 0x9705fa28242e06bc [count=2]
    192.168.255.237:500
    192.168.255.241:500
    IKE_LOG
    57
    2023-12-14 17:01:40
    info
    IKE
    Recv:[HASH][NOTIFY:R_U_THERE]
    192.168.255.241:500
    192.168.255.237:500
    IKE_LOG
    58
    2023-12-14 17:01:40
    info
    IKE
    The cookie pair is : 0x9705fa28242e06bc / 0xf6c98f4ae079b9ef [count=2]
    192.168.255.241:500
    192.168.255.237:500
    IKE_LOG
    65
    2023-12-14 17:01:37
    info
    IKE
    ISAKMP SA [link_to_VPN300_4G] is disconnected
    94.173.27.164:4500
    31.94.60.226:4500
    IKE_LOG
    66
    2023-12-14 17:01:37
    info
    IKE
    Send:[HASH][DEL] [count=3]
    94.173.27.164:4500
    31.94.60.226:4500
    IKE_LOG
    67
    2023-12-14 17:01:37
    info
    IKE
    The cookie pair is : 0x6f5ec2706ccb6b8a / 0x9e45a7a8c593da65 [count=4]
    94.173.27.164:4500
    31.94.60.226:4500
    IKE_LOG
    73
    2023-12-14 17:01:22
    info
    IKE
    94.173.27.164:4500
    31.94.60.226:4500
    IKE_LOG
    74
    2023-12-14 17:01:22
    info
    IKE
    Send:[ID][HASH]
    94.173.27.164:4500
    31.94.60.226:4500
    IKE_LOG
    75
    2023-12-14 17:01:22
    info
    IKE
    The cookie pair is : 0x6f5ec2706ccb6b8a / 0x9e45a7a8c593da65 [count=2]
    94.173.27.164:4500
    31.94.60.226:4500
    IKE_LOG
    76
    2023-12-14 17:01:22
    info
    IKE
    Recv:[ID][HASH]
    31.94.60.226:4500
    94.173.27.164:4500
    IKE_LOG
    77
    2023-12-14 17:01:22
    info
    IKE
    The cookie pair is : 0x9e45a7a8c593da65 / 0x6f5ec2706ccb6b8a
    31.94.60.226:4500
    94.173.27.164:4500
    IKE_LOG
    78
    2023-12-14 17:01:22
    info
    IKE
    94.173.27.164:500
    31.94.60.226:61072
    IKE_LOG
    79
    2023-12-14 17:01:22
    info
    IKE
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    80
    2023-12-14 17:01:22
    info
    IKE
    94.173.27.164:500
    31.94.60.226:61072
    IKE_LOG
    81
    2023-12-14 17:01:22
    info
    IKE
    94.173.27.164:500
    31.94.60.226:61072
    IKE_LOG
    82
    2023-12-14 17:01:22
    info
    IKE
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    83
    2023-12-14 17:01:22
    info
    IKE
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    84
    2023-12-14 17:01:22
    info
    IKE
    The cookie pair is : 0x9e45a7a8c593da65 / 0x6f5ec2706ccb6b8a [count=2]
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    85
    2023-12-14 17:01:22
    info
    IKE
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    86
    2023-12-14 17:01:22
    info
    IKE
    The cookie pair is : 0x6f5ec2706ccb6b8a / 0x0000000000000000
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    95
    2023-12-14 17:01:18
    info
    IKE
    192.168.255.241:500
    192.168.255.237:500
    IKE_LOG
    96
    2023-12-14 17:01:18
    info
    IKE
    192.168.255.237:500
    192.168.255.241:500
    IKE_LOG
    101
    2023-12-14 17:01:09
    info
    IKE
    192.168.255.237:500
    192.168.255.241:500
    IKE_LOG
    102
    2023-12-14 17:01:09
    info
    IKE
    192.168.255.237:500
    192.168.255.241:500
    IKE_LOG
    103
    2023-12-14 17:01:09
    info
    IKE
    192.168.255.241:500
    192.168.255.237:500
    IKE_LOG
    104
    2023-12-14 17:01:09
    info
    IKE
    192.168.255.241:500
    192.168.255.237:500
    IKE_LOG
    111
    2023-12-14 17:01:02
    info
    IKE
    94.173.27.164:4500
    31.94.60.226:4500
    IKE_LOG
    112
    2023-12-14 17:01:02
    info
    IKE
    94.173.27.164:4500
    31.94.60.226:4500
    IKE_LOG
    113
    2023-12-14 17:01:02
    info
    IKE
    The cookie pair is : 0x48d3191106ff126a / 0x653568bcfb5df654 [count=4]
    94.173.27.164:4500
    31.94.60.226:4500
    IKE_LOG
    120
    2023-12-14 17:00:49
    info
    IKE
    94.173.27.164:4500
    31.94.60.226:4500
    IKE_LOG
    121
    2023-12-14 17:00:49
    info
    IKE
    Send:[ID][HASH]
    94.173.27.164:4500
    31.94.60.226:4500
    IKE_LOG
    122
    2023-12-14 17:00:49
    info
    IKE
    The cookie pair is : 0x48d3191106ff126a / 0x653568bcfb5df654 [count=2]
    94.173.27.164:4500
    31.94.60.226:4500
    IKE_LOG
    123
    2023-12-14 17:00:49
    info
    IKE
    Recv:[ID][HASH]
    31.94.60.226:4500
    94.173.27.164:4500
    IKE_LOG
    124
    2023-12-14 17:00:49
    info
    IKE
    The cookie pair is : 0x653568bcfb5df654 / 0x48d3191106ff126a
    31.94.60.226:4500
    94.173.27.164:4500
    IKE_LOG
    125
    2023-12-14 17:00:49
    info
    IKE
    94.173.27.164:500
    31.94.60.226:61072
    IKE_LOG
    126
    2023-12-14 17:00:49
    info
    IKE
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    127
    2023-12-14 17:00:49
    info
    IKE
    94.173.27.164:500
    31.94.60.226:61072
    IKE_LOG
    128
    2023-12-14 17:00:49
    info
    IKE
    94.173.27.164:500
    31.94.60.226:61072
    IKE_LOG
    129
    2023-12-14 17:00:49
    info
    IKE
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    130
    2023-12-14 17:00:49
    info
    IKE
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    131
    2023-12-14 17:00:49
    info
    IKE
    The cookie pair is : 0x653568bcfb5df654 / 0x48d3191106ff126a [count=2]
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    132
    2023-12-14 17:00:49
    info
    IKE
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    133
    2023-12-14 17:00:49
    info
    IKE
    The cookie pair is : 0x48d3191106ff126a / 0x0000000000000000
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    135
    2023-12-14 17:00:47
    info
    IKE
    192.168.255.241:500
    192.168.255.237:500
    IKE_LOG
    136
    2023-12-14 17:00:47
    info
    IKE
    192.168.255.237:500
    192.168.255.241:500
    IKE_LOG
    140
    2023-12-14 17:00:38
    info
    IKE
    192.168.255.237:500
    192.168.255.241:500
    IKE_LOG
    141
    2023-12-14 17:00:38
    info
    IKE
    192.168.255.237:500
    192.168.255.241:500
    IKE_LOG
    142
    2023-12-14 17:00:38
    info
    IKE
    192.168.255.241:500
    192.168.255.237:500
    IKE_LOG
    143
    2023-12-14 17:00:38
    info
    IKE
    192.168.255.241:500
    192.168.255.237:500
    IKE_LOG
    149
    2023-12-14 17:00:31
    info
    IKE
    94.173.27.164:4500
    31.94.60.226:4500
    IKE_LOG
    150
    2023-12-14 17:00:31
    info
    IKE
    94.173.27.164:4500
    31.94.60.226:4500
    IKE_LOG
    151
    2023-12-14 17:00:31
    info
    IKE
    The cookie pair is : 0x72a201aa7a1cc0e0 / 0x6078b0045a86a43b [count=4]
    94.173.27.164:4500
    31.94.60.226:4500
    IKE_LOG
    160
    2023-12-14 17:00:17
    info
    IKE
    192.168.255.241:500
    192.168.255.237:500
    IKE_LOG
    161
    2023-12-14 17:00:17
    info
    IKE
    192.168.255.241:500
    192.168.255.237:500
    IKE_LOG
    162
    2023-12-14 17:00:17
    info
    IKE
    192.168.255.237:500
    192.168.255.241:500
    IKE_LOG
    163
    2023-12-14 17:00:17
    info
    IKE
    192.168.255.237:500
    192.168.255.241:500
    IKE_LOG
    164
    2023-12-14 17:00:15
    info
    IKE
    94.173.27.164:4500
    31.94.60.226:4500
    IKE_LOG
    165
    2023-12-14 17:00:15
    info
    IKE
    Send:[ID][HASH]
    94.173.27.164:4500
    31.94.60.226:4500
    IKE_LOG
    166
    2023-12-14 17:00:15
    info
    IKE
    The cookie pair is : 0x72a201aa7a1cc0e0 / 0x6078b0045a86a43b [count=2]
    94.173.27.164:4500
    31.94.60.226:4500
    IKE_LOG
    167
    2023-12-14 17:00:15
    info
    IKE
    Recv:[ID][HASH]
    31.94.60.226:4500
    94.173.27.164:4500
    IKE_LOG
    168
    2023-12-14 17:00:15
    info
    IKE
    The cookie pair is : 0x6078b0045a86a43b / 0x72a201aa7a1cc0e0
    31.94.60.226:4500
    94.173.27.164:4500
    IKE_LOG
    169
    2023-12-14 17:00:15
    info
    IKE
    94.173.27.164:500
    31.94.60.226:61072
    IKE_LOG
    170
    2023-12-14 17:00:15
    info
    IKE
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    171
    2023-12-14 17:00:15
    info
    IKE
    94.173.27.164:500
    31.94.60.226:61072
    IKE_LOG
    172
    2023-12-14 17:00:15
    info
    IKE
    94.173.27.164:500
    31.94.60.226:61072
    IKE_LOG
    173
    2023-12-14 17:00:15
    info
    IKE
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    174
    2023-12-14 17:00:15
    info
    IKE
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    175
    2023-12-14 17:00:15
    info
    IKE
    The cookie pair is : 0x6078b0045a86a43b / 0x72a201aa7a1cc0e0 [count=2]
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    176
    2023-12-14 17:00:15
    info
    IKE
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    177
    2023-12-14 17:00:15
    info
    IKE
    The cookie pair is : 0x72a201aa7a1cc0e0 / 0x0000000000000000
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    VPN300
    2023-12-14 17:01:55
    info
    IKE
    10.112.227.206:4500
    94.173.27.164:4500
    IKE_LOG
    2
    2023-12-14 17:01:55
    info
    IKE
    Recv:[ID][HASH]
    94.173.27.164:4500
    10.112.227.206:4500
    IKE_LOG
    3
    2023-12-14 17:01:55
    info
    IKE
    94.173.27.164:4500
    10.112.227.206:4500
    IKE_LOG
    4
    2023-12-14 17:01:55
    info
    IKE
    Send:[ID][HASH]
    10.112.227.206:4500
    94.173.27.164:4500
    IKE_LOG
    5
    2023-12-14 17:01:55
    info
    IKE
    10.112.227.206:4500
    94.173.27.164:4500
    IKE_LOG
    6
    2023-12-14 17:01:55
    info
    IKE
    94.173.27.164:500
    10.112.227.206:500
    IKE_LOG
    7
    2023-12-14 17:01:55
    info
    IKE
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
    8
    2023-12-14 17:01:55
    info
    IKE
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
    9
    2023-12-14 17:01:55
    info
    IKE
    94.173.27.164:500
    10.112.227.206:500
    IKE_LOG
    10
    2023-12-14 17:01:55
    info
    IKE
    94.173.27.164:500
    10.112.227.206:500
    IKE_LOG
    11
    2023-12-14 17:01:55
    info
    IKE
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
    12
    2023-12-14 17:01:55
    info
    IKE
    Send Main Mode request to [94.173.27.164]
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
    13
    2023-12-14 17:01:55
    info
    IKE
    Tunnel [link_to_flex200_4G] Sending IKE request
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
    14
    2023-12-14 17:01:55
    info
    IKE
    The cookie pair is : 0x9c9d06ae7a475c2f / 0x0000000000000000 [count=3]
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
    15
    2023-12-14 17:01:36
    info
    IKE
    [COOKIE] Invalid cookie, no sa found [count=2]
    10.112.227.206:500
    94.173.27.164:4500
    IKE_LOG
    16
    2023-12-14 17:01:36
    info
    IKE
    10.112.227.206:500
    94.173.27.164:4500
    IKE_LOG
    17
    2023-12-14 17:01:36
    info
    IKE
    ISAKMP SA [link_to_flex200_4G] is disconnected
    10.112.227.206:4500
    94.173.27.164:4500
    IKE_LOG
    18
    2023-12-14 17:01:36
    info
    IKE
    10.112.227.206:4500
    94.173.27.164:4500
    IKE_LOG
    19
    2023-12-14 17:01:36
    info
    IKE
    Received delete notification
    94.173.27.164:4500
    10.112.227.206:4500
    IKE_LOG
    20
    2023-12-14 17:01:36
    info
    IKE
    Recv:[HASH][DEL]
    94.173.27.164:4500
    10.112.227.206:4500
    IKE_LOG
    21
    2023-12-14 17:01:36
    info
    IKE
    94.173.27.164:4500
    10.112.227.206:4500
    IKE_LOG
    22
    2023-12-14 17:01:22
    info
    IKE
    10.112.227.206:4500
    94.173.27.164:4500
    IKE_LOG
    23
    2023-12-14 17:01:22
    info
    IKE
    Recv:[ID][HASH]
    94.173.27.164:4500
    10.112.227.206:4500
    IKE_LOG
    24
    2023-12-14 17:01:22
    info
    IKE
    94.173.27.164:4500
    10.112.227.206:4500
    IKE_LOG
    25
    2023-12-14 17:01:22
    info
    IKE
    Send:[ID][HASH]
    10.112.227.206:4500
    94.173.27.164:4500
    IKE_LOG
    26
    2023-12-14 17:01:22
    info
    IKE
    10.112.227.206:4500
    94.173.27.164:4500
    IKE_LOG
    27
    2023-12-14 17:01:22
    info
    IKE
    94.173.27.164:500
    10.112.227.206:500
    IKE_LOG
    28
    2023-12-14 17:01:22
    info
    IKE
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
    29
    2023-12-14 17:01:22
    info
    IKE
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
    30
    2023-12-14 17:01:21
    info
    IKE
    94.173.27.164:500
    10.112.227.206:500
    IKE_LOG
    31
    2023-12-14 17:01:21
    info
    IKE
    94.173.27.164:500
    10.112.227.206:500
    IKE_LOG
    32
    2023-12-14 17:01:21
    info
    IKE
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
    33
    2023-12-14 17:01:21
    info
    IKE
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
    34
    2023-12-14 17:01:21
    info
    IKE
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
    35
    2023-12-14 17:01:21
    info
    IKE
    The cookie pair is : 0x6f5ec2706ccb6b8a / 0x0000000000000000 [count=3]
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
    38
    2023-12-14 17:01:02
    info
    IKE
    10.112.227.206:500
    94.173.27.164:4500
    IKE_LOG
    39
    2023-12-14 17:01:02
    info
    IKE
    10.112.227.206:500
    94.173.27.164:4500
    IKE_LOG
    40
    2023-12-14 17:01:02
    info
    IKE
    10.112.227.206:4500
    94.173.27.164:4500
    IKE_LOG
    41
    2023-12-14 17:01:02
    info
    IKE
    10.112.227.206:4500
    94.173.27.164:4500
    IKE_LOG
    42
    2023-12-14 17:01:02
    info
    IKE
    94.173.27.164:4500
    10.112.227.206:4500
    IKE_LOG
    43
    2023-12-14 17:01:02
    info
    IKE
    Recv:[HASH][DEL]
    94.173.27.164:4500
    10.112.227.206:4500
    IKE_LOG
    44
    2023-12-14 17:01:02
    info
    IKE
    94.173.27.164:4500
    10.112.227.206:4500
    IKE_LOG
    45
    2023-12-14 17:00:48
    info
    IKE
    10.112.227.206:4500
    94.173.27.164:4500
    IKE_LOG
    46
    2023-12-14 17:00:48
    info
    IKE
    Recv:[ID][HASH]
    94.173.27.164:4500
    10.112.227.206:4500
    IKE_LOG
    47
    2023-12-14 17:00:48
    info
    IKE
    94.173.27.164:4500
    10.112.227.206:4500
    IKE_LOG
    48
    2023-12-14 17:00:48
    info
    IKE
    Send:[ID][HASH]
    10.112.227.206:4500
    94.173.27.164:4500
    IKE_LOG
    49
    2023-12-14 17:00:48
    info
    IKE
    10.112.227.206:4500
    94.173.27.164:4500
    IKE_LOG
    50
    2023-12-14 17:00:48
    info
    IKE
    94.173.27.164:500
    10.112.227.206:500
    IKE_LOG
    51
    2023-12-14 17:00:48
    info
    IKE
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
    52
    2023-12-14 17:00:48
    info
    IKE
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
    53
    2023-12-14 17:00:48
    info
    IKE
    94.173.27.164:500
    10.112.227.206:500
    IKE_LOG
    54
    2023-12-14 17:00:48
    info
    IKE
    94.173.27.164:500
    10.112.227.206:500
    IKE_LOG
    55
    2023-12-14 17:00:48
    info
    IKE
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
    56
    2023-12-14 17:00:48
    info
    IKE
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
    57
    2023-12-14 17:00:48
    info
    IKE
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
    58
    2023-12-14 17:00:48
    info
    IKE
    The cookie pair is : 0x48d3191106ff126a / 0x0000000000000000 [count=3]
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
    59
    2023-12-14 17:00:30
    info
    IKE
    10.112.227.206:500
    94.173.27.164:4500
    IKE_LOG
    60
    2023-12-14 17:00:30
    info
    IKE
    10.112.227.206:500
    94.173.27.164:4500
    IKE_LOG
    61
    2023-12-14 17:00:30
    info
    IKE
    10.112.227.206:4500
    94.173.27.164:4500
    IKE_LOG
    62
    2023-12-14 17:00:30
    info
    IKE
    10.112.227.206:4500
    94.173.27.164:4500
    IKE_LOG
    63
    2023-12-14 17:00:30
    info
    IKE
    94.173.27.164:4500
    10.112.227.206:4500
    IKE_LOG
    64
    2023-12-14 17:00:30
    info
    IKE
    Recv:[HASH][DEL]
    94.173.27.164:4500
    10.112.227.206:4500
    IKE_LOG
    65
    2023-12-14 17:00:30
    info
    IKE
    94.173.27.164:4500
    10.112.227.206:4500
    IKE_LOG
    66
    2023-12-14 17:00:15
    info
    IKE
    10.112.227.206:4500
    94.173.27.164:4500
    IKE_LOG
    67
    2023-12-14 17:00:15
    info
    IKE
    Recv:[ID][HASH]
    94.173.27.164:4500
    10.112.227.206:4500
    IKE_LOG
    68
    2023-12-14 17:00:15
    info
    IKE
    94.173.27.164:4500
    10.112.227.206:4500
    IKE_LOG
    69
    2023-12-14 17:00:15
    info
    IKE
    Send:[ID][HASH]
    10.112.227.206:4500
    94.173.27.164:4500
    IKE_LOG
    70
    2023-12-14 17:00:15
    info
    IKE
    10.112.227.206:4500
    94.173.27.164:4500
    IKE_LOG
    71
    2023-12-14 17:00:15
    info
    IKE
    94.173.27.164:500
    10.112.227.206:500
    IKE_LOG
    72
    2023-12-14 17:00:15
    info
    IKE
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
    73
    2023-12-14 17:00:15
    info
    IKE
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
    74
    2023-12-14 17:00:14
    info
    IKE
    94.173.27.164:500
    10.112.227.206:500
    IKE_LOG
    75
    2023-12-14 17:00:14
    info
    IKE
    94.173.27.164:500
    10.112.227.206:500
    IKE_LOG
    76
    2023-12-14 17:00:14
    info
    IKE
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
    77
    2023-12-14 17:00:14
    info
    IKE
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
    78
    2023-12-14 17:00:14
    info
    IKE
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
    79
    2023-12-14 17:00:14
    info
    IKE
    The cookie pair is : 0x72a201aa7a1cc0e0 / 0x0000000000000000 [count=3]
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
    edited December 2023
    Its happened again
    V5.37(xxxx.1)
    one thing I notice was the VPN300 goes out by CGNAT to Flex200 which its source port will change but the logs don't show this
    Flex 200
    3
    2023-12-14 17:01:56
    info
    IKE
    94.173.27.164:4500
    31.94.60.226:4500
    IKE_LOG
    4
    2023-12-14 17:01:56
    info
    IKE
    Send:[ID][HASH]
    94.173.27.164:4500
    31.94.60.226:4500
    IKE_LOG
    5
    2023-12-14 17:01:56
    info
    IKE
    94.173.27.164:4500
    31.94.60.226:4500
    IKE_LOG
    6
    2023-12-14 17:01:56
    info
    IKE
    Recv:[ID][HASH]
    31.94.60.226:4500
    94.173.27.164:4500
    IKE_LOG
    7
    2023-12-14 17:01:56
    info
    IKE
    31.94.60.226:4500
    94.173.27.164:4500
    IKE_LOG
    8
    2023-12-14 17:01:56
    info
    IKE
    94.173.27.164:500
    31.94.60.226:61072
    IKE_LOG
    9
    2023-12-14 17:01:56
    info
    IKE
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    10
    2023-12-14 17:01:55
    info
    IKE
    94.173.27.164:500
    31.94.60.226:61072
    IKE_LOG
    11
    2023-12-14 17:01:55
    info
    IKE
    94.173.27.164:500
    31.94.60.226:61072
    IKE_LOG
    12
    2023-12-14 17:01:55
    info
    IKE
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    13
    2023-12-14 17:01:55
    info
    IKE
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    14
    2023-12-14 17:01:55
    info
    IKE
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    15
    2023-12-14 17:01:55
    info
    IKE
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    16
    2023-12-14 17:01:55
    info
    IKE
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    31
    2023-12-14 17:01:49
    info
    IKE
    192.168.255.241:500
    192.168.255.237:500
    IKE_LOG
    32
    2023-12-14 17:01:49
    info
    IKE
    192.168.255.237:500
    192.168.255.241:500
    IKE_LOG
    55
    2023-12-14 17:01:40
    info
    IKE
    192.168.255.237:500
    192.168.255.241:500
    IKE_LOG
    56
    2023-12-14 17:01:40
    info
    IKE
    192.168.255.237:500
    192.168.255.241:500
    IKE_LOG
    57
    2023-12-14 17:01:40
    info
    IKE
    192.168.255.241:500
    192.168.255.237:500
    IKE_LOG
    58
    2023-12-14 17:01:40
    info
    IKE
    192.168.255.241:500
    192.168.255.237:500
    IKE_LOG
    65
    2023-12-14 17:01:37
    info
    IKE
    94.173.27.164:4500
    31.94.60.226:4500
    IKE_LOG
    66
    2023-12-14 17:01:37
    info
    IKE
    94.173.27.164:4500
    31.94.60.226:4500
    IKE_LOG
    67
    2023-12-14 17:01:37
    info
    IKE
    94.173.27.164:4500
    31.94.60.226:4500
    IKE_LOG
    73
    2023-12-14 17:01:22
    info
    IKE
    94.173.27.164:4500
    31.94.60.226:4500
    IKE_LOG
    74
    2023-12-14 17:01:22
    info
    IKE
    Send:[ID][HASH]
    94.173.27.164:4500
    31.94.60.226:4500
    IKE_LOG
    75
    2023-12-14 17:01:22
    info
    IKE
    94.173.27.164:4500
    31.94.60.226:4500
    IKE_LOG
    76
    2023-12-14 17:01:22
    info
    IKE
    Recv:[ID][HASH]
    31.94.60.226:4500
    94.173.27.164:4500
    IKE_LOG
    77
    2023-12-14 17:01:22
    info
    IKE
    31.94.60.226:4500
    94.173.27.164:4500
    IKE_LOG
    78
    2023-12-14 17:01:22
    info
    IKE
    94.173.27.164:500
    31.94.60.226:61072
    IKE_LOG
    79
    2023-12-14 17:01:22
    info
    IKE
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    80
    2023-12-14 17:01:22
    info
    IKE
    94.173.27.164:500
    31.94.60.226:61072
    IKE_LOG
    81
    2023-12-14 17:01:22
    info
    IKE
    94.173.27.164:500
    31.94.60.226:61072
    IKE_LOG
    82
    2023-12-14 17:01:22
    info
    IKE
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    83
    2023-12-14 17:01:22
    info
    IKE
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    84
    2023-12-14 17:01:22
    info
    IKE
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    85
    2023-12-14 17:01:22
    info
    IKE
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    86
    2023-12-14 17:01:22
    info
    IKE
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    95
    2023-12-14 17:01:18
    info
    IKE
    192.168.255.241:500
    192.168.255.237:500
    IKE_LOG
    96
    2023-12-14 17:01:18
    info
    IKE
    192.168.255.237:500
    192.168.255.241:500
    IKE_LOG
    101
    2023-12-14 17:01:09
    info
    IKE
    192.168.255.237:500
    192.168.255.241:500
    IKE_LOG
    102
    2023-12-14 17:01:09
    info
    IKE
    192.168.255.237:500
    192.168.255.241:500
    IKE_LOG
    103
    2023-12-14 17:01:09
    info
    IKE
    192.168.255.241:500
    192.168.255.237:500
    IKE_LOG
    104
    2023-12-14 17:01:09
    info
    IKE
    192.168.255.241:500
    192.168.255.237:500
    IKE_LOG
    111
    2023-12-14 17:01:02
    info
    IKE
    94.173.27.164:4500
    31.94.60.226:4500
    IKE_LOG
    112
    2023-12-14 17:01:02
    info
    IKE
    94.173.27.164:4500
    31.94.60.226:4500
    IKE_LOG
    113
    2023-12-14 17:01:02
    info
    IKE
    94.173.27.164:4500
    31.94.60.226:4500
    IKE_LOG
    120
    2023-12-14 17:00:49
    info
    IKE
    94.173.27.164:4500
    31.94.60.226:4500
    IKE_LOG
    121
    2023-12-14 17:00:49
    info
    IKE
    Send:[ID][HASH]
    94.173.27.164:4500
    31.94.60.226:4500
    IKE_LOG
    122
    2023-12-14 17:00:49
    info
    IKE
    94.173.27.164:4500
    31.94.60.226:4500
    IKE_LOG
    123
    2023-12-14 17:00:49
    info
    IKE
    Recv:[ID][HASH]
    31.94.60.226:4500
    94.173.27.164:4500
    IKE_LOG
    124
    2023-12-14 17:00:49
    info
    IKE
    31.94.60.226:4500
    94.173.27.164:4500
    IKE_LOG
    125
    2023-12-14 17:00:49
    info
    IKE
    94.173.27.164:500
    31.94.60.226:61072
    IKE_LOG
    126
    2023-12-14 17:00:49
    info
    IKE
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    127
    2023-12-14 17:00:49
    info
    IKE
    94.173.27.164:500
    31.94.60.226:61072
    IKE_LOG
    128
    2023-12-14 17:00:49
    info
    IKE
    94.173.27.164:500
    31.94.60.226:61072
    IKE_LOG
    129
    2023-12-14 17:00:49
    info
    IKE
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    130
    2023-12-14 17:00:49
    info
    IKE
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    131
    2023-12-14 17:00:49
    info
    IKE
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    132
    2023-12-14 17:00:49
    info
    IKE
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    133
    2023-12-14 17:00:49
    info
    IKE
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    135
    2023-12-14 17:00:47
    info
    IKE
    192.168.255.241:500
    192.168.255.237:500
    IKE_LOG
    136
    2023-12-14 17:00:47
    info
    IKE
    192.168.255.237:500
    192.168.255.241:500
    IKE_LOG
    140
    2023-12-14 17:00:38
    info
    IKE
    192.168.255.237:500
    192.168.255.241:500
    IKE_LOG
    141
    2023-12-14 17:00:38
    info
    IKE
    192.168.255.237:500
    192.168.255.241:500
    IKE_LOG
    142
    2023-12-14 17:00:38
    info
    IKE
    192.168.255.241:500
    192.168.255.237:500
    IKE_LOG
    143
    2023-12-14 17:00:38
    info
    IKE
    192.168.255.241:500
    192.168.255.237:500
    IKE_LOG
    149
    2023-12-14 17:00:31
    info
    IKE
    94.173.27.164:4500
    31.94.60.226:4500
    IKE_LOG
    150
    2023-12-14 17:00:31
    info
    IKE
    94.173.27.164:4500
    31.94.60.226:4500
    IKE_LOG
    151
    2023-12-14 17:00:31
    info
    IKE
    94.173.27.164:4500
    31.94.60.226:4500
    IKE_LOG
    160
    2023-12-14 17:00:17
    info
    IKE
    192.168.255.241:500
    192.168.255.237:500
    IKE_LOG
    161
    2023-12-14 17:00:17
    info
    IKE
    192.168.255.241:500
    192.168.255.237:500
    IKE_LOG
    162
    2023-12-14 17:00:17
    info
    IKE
    192.168.255.237:500
    192.168.255.241:500
    IKE_LOG
    163
    2023-12-14 17:00:17
    info
    IKE
    192.168.255.237:500
    192.168.255.241:500
    IKE_LOG
    164
    2023-12-14 17:00:15
    info
    IKE
    94.173.27.164:4500
    31.94.60.226:4500
    IKE_LOG
    165
    2023-12-14 17:00:15
    info
    IKE
    Send:[ID][HASH]
    94.173.27.164:4500
    31.94.60.226:4500
    IKE_LOG
    166
    2023-12-14 17:00:15
    info
    IKE
    94.173.27.164:4500
    31.94.60.226:4500
    IKE_LOG
    167
    2023-12-14 17:00:15
    info
    IKE
    Recv:[ID][HASH]
    31.94.60.226:4500
    94.173.27.164:4500
    IKE_LOG
    168
    2023-12-14 17:00:15
    info
    IKE
    31.94.60.226:4500
    94.173.27.164:4500
    IKE_LOG
    169
    2023-12-14 17:00:15
    info
    IKE
    94.173.27.164:500
    31.94.60.226:61072
    IKE_LOG
    170
    2023-12-14 17:00:15
    info
    IKE
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    171
    2023-12-14 17:00:15
    info
    IKE
    94.173.27.164:500
    31.94.60.226:61072
    IKE_LOG
    172
    2023-12-14 17:00:15
    info
    IKE
    94.173.27.164:500
    31.94.60.226:61072
    IKE_LOG
    173
    2023-12-14 17:00:15
    info
    IKE
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    174
    2023-12-14 17:00:15
    info
    IKE
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    175
    2023-12-14 17:00:15
    info
    IKE
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    176
    2023-12-14 17:00:15
    info
    IKE
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    177
    2023-12-14 17:00:15
    info
    IKE
    31.94.60.226:61072
    94.173.27.164:500
    IKE_LOG
    VPN300
    2023-12-14 17:01:55
    info
    IKE
    10.112.227.206:4500
    94.173.27.164:4500
    IKE_LOG
    2
    2023-12-14 17:01:55
    info
    IKE
    Recv:[ID][HASH]
    94.173.27.164:4500
    10.112.227.206:4500
    IKE_LOG
    3
    2023-12-14 17:01:55
    info
    IKE
    94.173.27.164:4500
    10.112.227.206:4500
    IKE_LOG
    4
    2023-12-14 17:01:55
    info
    IKE
    Send:[ID][HASH]
    10.112.227.206:4500
    94.173.27.164:4500
    IKE_LOG
    5
    2023-12-14 17:01:55
    info
    IKE
    10.112.227.206:4500
    94.173.27.164:4500
    IKE_LOG
    6
    2023-12-14 17:01:55
    info
    IKE
    94.173.27.164:500
    10.112.227.206:500
    IKE_LOG
    7
    2023-12-14 17:01:55
    info
    IKE
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
    8
    2023-12-14 17:01:55
    info
    IKE
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
    9
    2023-12-14 17:01:55
    info
    IKE
    94.173.27.164:500
    10.112.227.206:500
    IKE_LOG
    10
    2023-12-14 17:01:55
    info
    IKE
    94.173.27.164:500
    10.112.227.206:500
    IKE_LOG
    11
    2023-12-14 17:01:55
    info
    IKE
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
    12
    2023-12-14 17:01:55
    info
    IKE
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
    13
    2023-12-14 17:01:55
    info
    IKE
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
    14
    2023-12-14 17:01:55
    info
    IKE
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
    15
    2023-12-14 17:01:36
    info
    IKE
    10.112.227.206:500
    94.173.27.164:4500
    IKE_LOG
    16
    2023-12-14 17:01:36
    info
    IKE
    10.112.227.206:500
    94.173.27.164:4500
    IKE_LOG
    17
    2023-12-14 17:01:36
    info
    IKE
    10.112.227.206:4500
    94.173.27.164:4500
    IKE_LOG
    18
    2023-12-14 17:01:36
    info
    IKE
    10.112.227.206:4500
    94.173.27.164:4500
    IKE_LOG
    19
    2023-12-14 17:01:36
    info
    IKE
    94.173.27.164:4500
    10.112.227.206:4500
    IKE_LOG
    20
    2023-12-14 17:01:36
    info
    IKE
    Recv:[HASH][DEL]
    94.173.27.164:4500
    10.112.227.206:4500
    IKE_LOG
    21
    2023-12-14 17:01:36
    info
    IKE
    94.173.27.164:4500
    10.112.227.206:4500
    IKE_LOG
    22
    2023-12-14 17:01:22
    info
    IKE
    10.112.227.206:4500
    94.173.27.164:4500
    IKE_LOG
    23
    2023-12-14 17:01:22
    info
    IKE
    Recv:[ID][HASH]
    94.173.27.164:4500
    10.112.227.206:4500
    IKE_LOG
    24
    2023-12-14 17:01:22
    info
    IKE
    94.173.27.164:4500
    10.112.227.206:4500
    IKE_LOG
    25
    2023-12-14 17:01:22
    info
    IKE
    Send:[ID][HASH]
    10.112.227.206:4500
    94.173.27.164:4500
    IKE_LOG
    26
    2023-12-14 17:01:22
    info
    IKE
    10.112.227.206:4500
    94.173.27.164:4500
    IKE_LOG
    27
    2023-12-14 17:01:22
    info
    IKE
    94.173.27.164:500
    10.112.227.206:500
    IKE_LOG
    28
    2023-12-14 17:01:22
    info
    IKE
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
    29
    2023-12-14 17:01:22
    info
    IKE
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
    30
    2023-12-14 17:01:21
    info
    IKE
    94.173.27.164:500
    10.112.227.206:500
    IKE_LOG
    31
    2023-12-14 17:01:21
    info
    IKE
    94.173.27.164:500
    10.112.227.206:500
    IKE_LOG
    32
    2023-12-14 17:01:21
    info
    IKE
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
    33
    2023-12-14 17:01:21
    info
    IKE
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
    34
    2023-12-14 17:01:21
    info
    IKE
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
    35
    2023-12-14 17:01:21
    info
    IKE
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
    38
    2023-12-14 17:01:02
    info
    IKE
    10.112.227.206:500
    94.173.27.164:4500
    IKE_LOG
    39
    2023-12-14 17:01:02
    info
    IKE
    10.112.227.206:500
    94.173.27.164:4500
    IKE_LOG
    40
    2023-12-14 17:01:02
    info
    IKE
    10.112.227.206:4500
    94.173.27.164:4500
    IKE_LOG
    41
    2023-12-14 17:01:02
    info
    IKE
    10.112.227.206:4500
    94.173.27.164:4500
    IKE_LOG
    42
    2023-12-14 17:01:02
    info
    IKE
    94.173.27.164:4500
    10.112.227.206:4500
    IKE_LOG
    43
    2023-12-14 17:01:02
    info
    IKE
    Recv:[HASH][DEL]
    94.173.27.164:4500
    10.112.227.206:4500
    IKE_LOG
    44
    2023-12-14 17:01:02
    info
    IKE
    94.173.27.164:4500
    10.112.227.206:4500
    IKE_LOG
    45
    2023-12-14 17:00:48
    info
    IKE
    10.112.227.206:4500
    94.173.27.164:4500
    IKE_LOG
    46
    2023-12-14 17:00:48
    info
    IKE
    Recv:[ID][HASH]
    94.173.27.164:4500
    10.112.227.206:4500
    IKE_LOG
    47
    2023-12-14 17:00:48
    info
    IKE
    94.173.27.164:4500
    10.112.227.206:4500
    IKE_LOG
    48
    2023-12-14 17:00:48
    info
    IKE
    Send:[ID][HASH]
    10.112.227.206:4500
    94.173.27.164:4500
    IKE_LOG
    49
    2023-12-14 17:00:48
    info
    IKE
    10.112.227.206:4500
    94.173.27.164:4500
    IKE_LOG
    50
    2023-12-14 17:00:48
    info
    IKE
    94.173.27.164:500
    10.112.227.206:500
    IKE_LOG
    51
    2023-12-14 17:00:48
    info
    IKE
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
    52
    2023-12-14 17:00:48
    info
    IKE
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
    53
    2023-12-14 17:00:48
    info
    IKE
    94.173.27.164:500
    10.112.227.206:500
    IKE_LOG
    54
    2023-12-14 17:00:48
    info
    IKE
    94.173.27.164:500
    10.112.227.206:500
    IKE_LOG
    55
    2023-12-14 17:00:48
    info
    IKE
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
    56
    2023-12-14 17:00:48
    info
    IKE
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
    57
    2023-12-14 17:00:48
    info
    IKE
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
    58
    2023-12-14 17:00:48
    info
    IKE
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
    59
    2023-12-14 17:00:30
    info
    IKE
    10.112.227.206:500
    94.173.27.164:4500
    IKE_LOG
    60
    2023-12-14 17:00:30
    info
    IKE
    10.112.227.206:500
    94.173.27.164:4500
    IKE_LOG
    61
    2023-12-14 17:00:30
    info
    IKE
    10.112.227.206:4500
    94.173.27.164:4500
    IKE_LOG
    62
    2023-12-14 17:00:30
    info
    IKE
    10.112.227.206:4500
    94.173.27.164:4500
    IKE_LOG
    63
    2023-12-14 17:00:30
    info
    IKE
    94.173.27.164:4500
    10.112.227.206:4500
    IKE_LOG
    64
    2023-12-14 17:00:30
    info
    IKE
    Recv:[HASH][DEL]
    94.173.27.164:4500
    10.112.227.206:4500
    IKE_LOG
    65
    2023-12-14 17:00:30
    info
    IKE
    94.173.27.164:4500
    10.112.227.206:4500
    IKE_LOG
    66
    2023-12-14 17:00:15
    info
    IKE
    10.112.227.206:4500
    94.173.27.164:4500
    IKE_LOG
    67
    2023-12-14 17:00:15
    info
    IKE
    Recv:[ID][HASH]
    94.173.27.164:4500
    10.112.227.206:4500
    IKE_LOG
    68
    2023-12-14 17:00:15
    info
    IKE
    94.173.27.164:4500
    10.112.227.206:4500
    IKE_LOG
    69
    2023-12-14 17:00:15
    info
    IKE
    Send:[ID][HASH]
    10.112.227.206:4500
    94.173.27.164:4500
    IKE_LOG
    70
    2023-12-14 17:00:15
    info
    IKE
    10.112.227.206:4500
    94.173.27.164:4500
    IKE_LOG
    71
    2023-12-14 17:00:15
    info
    IKE
    94.173.27.164:500
    10.112.227.206:500
    IKE_LOG
    72
    2023-12-14 17:00:15
    info
    IKE
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
    73
    2023-12-14 17:00:15
    info
    IKE
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
    74
    2023-12-14 17:00:14
    info
    IKE
    94.173.27.164:500
    10.112.227.206:500
    IKE_LOG
    75
    2023-12-14 17:00:14
    info
    IKE
    94.173.27.164:500
    10.112.227.206:500
    IKE_LOG
    76
    2023-12-14 17:00:14
    info
    IKE
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
    77
    2023-12-14 17:00:14
    info
    IKE
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
    78
    2023-12-14 17:00:14
    info
    IKE
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
    79
    2023-12-14 17:00:14
    info
    IKE
    10.112.227.206:500
    94.173.27.164:500
    IKE_LOG
  • Omnia
    Omnia Posts: 60 image  Ally Member
    Have you make a bwm on your tunnel?
    I have BWM enabled but no rules for the tunnel
    Two way traffic is happening but the VPN300 set to nailed up loses connection tries and tries to reconnect but only when I disable the VPN and enable it again does the tunnel work again.
  • Zyxel_Cooldia
    Hi @PeterUK ,
    Can you provide the device web gui access in PM. we would like to check the device runtime status.
    edited January 2024
    So its been stable since disabling/enable the VPN so I'm now thinking this might happen once after a firmware update or power off and on which I have now done and will check in 20days.
    Another reason but hard to check with CGNAT by 4G is if the VPN300 makes a connection out the CGNAT with source port 4500 as normally that changes should it once connect out with source port 4500 then change to a random port that then causes this problem.
    Happened again with V5.37(ABFC.2) PM sent
